The current (modern) way to write that statement would be
Particle.variable("led1state", led1state);
But where do you have that instruction?
When does it execute when you boot up your device?
Can you show more of your code?
Do you really have a blank between ? and access_token in your path?
As it this is a GET request, you can read the variable just with a normal browser.
Okay, this command is now in Setup():
Particle.variable(“led1state”, led1state);
When I toggle: Console shows this: {“data”:“ON”,“ttl”:“60”,“published_at”:“2017-05-03T21:16:59.793Z”,“coreid”:“410049001051363036373538”,“name”:“led1state”}
Particle.publish() and Particle.variable() are two completely different things.
Maybe choose a different name for the event (e.g. Particle.publish("eventLedState", ...)) to distinguish the two.
As you can see, I’ve just modified one of the samples … “Web-Connected LED”. I reversed the names of the LEDS, so I could use the D7 led rather than wiring a breadboard.
// Controlling LEDs over the Internet
// First, let's create our "shorthand" for the pins
// Same as in the Blink an LED example:
// led1 is D0, led2 is D7
int led2 = D0;
int led1 = D7;
String led1state="";
// Last time, we only needed to declare pins in the setup function.
// This time, we are also going to register our Particle function
// Here's the pin configuration, same as last time
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
// We are also going to declare a Particle.function so that we can turn the LED on and off from the cloud.
Particle.function("led",ledToggle);
// This is saying that when we ask the cloud for the function "led", it will employ the function ledToggle() from this app.
// For good measure, let's also make sure both LEDs are off when we start:
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
// Last time, we wanted to continously blink the LED on and off
// Since we're waiting for input through the cloud this time,
// we don't actually need to put anything in the loop
// Nothing to do here
// We're going to have a super cool function now that gets called when a matching API request is sent
// This is the ledToggle function we registered to the "led" Particle.function earlier.
int ledToggle(String command) {
/* Particle.functions always take a string as an argument and return an integer.
Since we can pass a string, it means that we can give the program commands on how the function should be used.
In this case, telling the function "on" will turn the LED on and telling it "off" will turn the LED off.
Then, the function returns a value to us to let us know what happened.
In this case, it will return 1 for the LEDs turning on, 0 for the LEDs turning off,
and -1 if we received a totally bogus command that didn't do anything to the LEDs.
if (command=="on") {
digitalWrite(led1,HIGH);
digitalWrite(led2,HIGH);
//Particle.publish("pushbullet","LED Turned On!", 60, PRIVATE);
Particle.publish("led1state","ON");
return 1;
else if (command=="off") {
digitalWrite(led1,LOW);
digitalWrite(led2,LOW);
//Particle.publish("pushbullet","LED Turned Off!", 60, PRIVATE);
Particle.publish("led1state","OFF");
return 0;
else {
return -1;
Since your led1state is a String you should never had used this, but the new syntax got that sorted already.
But I don't see your code ever assigning anything to led1state - why is that?
As I said Particle.publish() doesn't do anything to any variables, so you need to have some led1state = command; (or similar) in your code.
Once you have that you should see the variable change in the console https://console.particle.io/devices
when you click on your device.
And navigating in a browser to https://api.particle.io/v1/devices/<deviceID>/led1state?access_token=<accessToken>
will give you something like this
Okay, I was able to work through things with the information that you provided. The URL was the key that unlocked the door. The code samples that I had reviewed always seemed to show Particle.publish publishing the Particle.variable … so that is how I thought we exposed the variable. Now I know that is not right. Once you declare the Particle.variable, the URL (or Tasker) can display that variable when you execute them. That is the functionality that I was looking for, so I ended up commenting out the Particle.publish lines in my code. I assume we use Particle.publish to actively push data to other places on the net. This data can be the Particle variable or anything else that we want to push. Please let me know if that is incorrect.
Thanks again for the time you spent helping me work through this. Looking back, I realize that I overlooked a couple of the questions that you asked. I apologize for that. I simply didn’t see them.
Along my journey to better understanding, I decided to simplify my code. I attach the final version here. Someone else may find it and your comments useful:
Note: the Particle.variable name changed to from “led1state” to “led” in the process.
// LedTest
const int LED_PIN = D7;
String led;
pinMode(LED_PIN, OUTPUT);
Particle.function("ledToggle",ledToggle);
Particle.variable("led",led);
ledToggle("OFF");
if (command == "ON") {
digitalWrite(LED_PIN,HIGH);
led = "ON";
//Particle.publish("led","ON");
} else if (command == "OFF") {
led = "OFF";
digitalWrite(LED_PIN,LOW);
//Particle.publish("led","OFF");
} else {
return -1;
return 0;
