I figured I could just write a separate block read function for each variable I need to read and then as you mention just save the data directly into the correct variable.
The only downside to that is how many functions this fuel gauge has that require a block read.
For example here are all the registers on the fuel gauge that require a Block Read and each of them return different amounts of data. I’ll have to try to figure out a way to efficiently save the returned data from all these block reads directly into the properly variables
int BQ20Z45::GaugingStatus(char *result)
return readStringB(BQ20Z45_GaugingStatus, result);
int BQ20Z45::SafetyAlert(char *result)
return readStringB(BQ20Z45_SafetyAlert, result);
int BQ20Z45::SafetyStatus(char *result)
return readStringB(BQ20Z45_SafetyStatus, result);
int BQ20Z45::PFAlert(char *result)
return readStringB(BQ20Z45_PFAlert, result);
int BQ20Z45::PFStatus(char *result)
return readStringB(BQ20Z45_PFStatus, result);
int BQ20Z45::OperationStatus(char *result)
return readStringB(BQ20Z45_OperationStatus, result);
int BQ20Z45::ChargingStatus(char *result)
return readStringB(BQ20Z45_ChargingStatus, result);
int BQ20Z45::ManufacturingStatus(char *result)
return readStringB(BQ20Z45_ManufacturingStatus, result);
int BQ20Z45::GetLifetimeDataBlock1(char *result)
return readStringB(BQ20Z45_LifetimeDataBlock1, result);
int BQ20Z45::GetLifetimeDataBlock2(char *result) // Last 2 returns on BQ Studio are different, PEC maybe?
return readStringB(BQ20Z45_LifetimeDataBlock2, result);
int BQ20Z45::GetLifetimeDataBlock3(char *result)
return readStringB(BQ20Z45_LifetimeDataBlock3, result);
int BQ20Z45::GetLifetimeDataBlock4(char *result)
return readStringB(BQ20Z45_LifetimeDataBlock4, result);
int BQ20Z45::GetLifetimeDataBlock5(char *result)
return readStringB(BQ20Z45_LifetimeDataBlock5, result);
int BQ20Z45::GetLifetimeDataBlock6(char *result)
return readStringB(BQ20Z45_LifetimeDataBlock6, result);
Yes, that makes perfect sense and I understand how that works conceptually but right now I’m not 100% sure exactly which of the 4 separate clumps of code need changed to send the result to their corresponding variables.
Some registers will return 32 bytes of status data so I could just instead of sending the data to a Char I can just send it to a uint32_t variable instead. Right?
I’ve tried making some changes to the .H & .CPP code for the bms.GaugingStatus(strBuffer); in an attempt to get it setup to pass the data into a new variable but so far with no luck
If you could provide some sort working example it would save me tons of time and I will then be able to change the other 15+ functions over to this new method also which further burn the correct way to do this into my mind.
If you want me to figure this out the hard & long way then I understand
Below is my current code structure.
Here is the .ino file:
#include "BQ20Z45.h" //Include BQ78350 Header File
// Store an instance of the BQ20Z45 Sensor
BQ20Z45 bms;
char strBuffer[33]; // This is a Buffer to store 32 bit data strings read from the BQ78350 Fuel Gauge. Not Sure if this is the best place for this code.
void setup(void)
// We start the serial library to output our messages.
Serial.begin(115200);
// Start i2c communication.
Wire.begin();
void loop(void)
//Serial.println("Gauging Status");
delay(4000);
#include "application.h"
//#include "Arduino.h"
// Functions Below
// pass a pointer to a char[] that can take up to 33 chars
// will return the length of the string received
int BQ20Z45::readStringB(uint8_t address, char* result)
int pos = 0;
int len;
// Read the length of the string
Wire.beginTransmission(BQ20Z45_Address); //Setup Write to Gauge
Wire.write(0x44); //Manufacturer Block Read
Wire.write(0x02); //How Many Bytes to expect Next
Wire.write(address); //Manufacturer Access Command - Example 0x01 Device Type
Wire.write(0x00); //First Byte of Command
Wire.endTransmission(true); //Repeated Start = True
Wire.requestFrom(BQ20Z45_Address, 1, true); //Setup Reading of Returned Data
len = Wire.read(); // length of the string thats about to return
len++; // plus one to allow for the length byte on the reread
// if len > 32 then the it will be truncated to 32 by requestFrom
len = Wire.requestFrom(BQ20Z45_Address, len, true); // readRequest returns # bytes actually read
len--; // we won't move the first 3 bytes as its not part of the string
len--;
len--;
if (len > 0)
Wire.read();
Wire.read();
Wire.read();
for (pos = 0; pos < len; pos++)
result[pos] = Wire.read();
result[pos] = '\0'; // append the zero terminator
return len;
// Class Methods Below
No need to change anything in the “library” just the call in .ino itself would be sufficient.
Although having a “typesafe” function that will only read the allowed number of bytes and flush the rest would be good practice.
little hint
// don't need that any more --> char strBuffer[33]; <--
// but this
uint16_t gaugeStatus = 0;
void loop(void)
// this used to be
//bms.GaugingStatus(strBuffer);
// but what now?
Based on what you are telling me I’m pretty sure I have the code right, see below:
BQ20Z45 bms;
//char strBuffer[33]; // This is a Buffer to store 32 bit data strings read from the BQ78350 Fuel Gauge. Not Sure if this is the best place for this code.
uint16_t GaugingStatus = 0;
void setup(void)
Wire.begin();
void loop(void)
bms.GaugingStatus(GaugingStatus);
Serial.println("");
Serial.println("------------------------------");
Serial.println("");
delay(4000);
But that throws this compile error. Of course it couldn’t be as simple as just changing strBuffer to GaugingStatus
I went into the .H and .CPP files and tried changing char to uint16_t step by step but I only created more compile errors.
You know more than I do about all this and you said I could leave the library alone and just change the pointer from strBuffer to another variable location but that’s not working.
Before I go digging further into trying to copy my other read functions that return uint16_t data I have to ask if you think the compile error may be caused by a problem with Particle DEV or if it’s a mismatch of data types in the functions in the .H & .CPP files?
The magic words are type cast and address of operator (&)
Update:
With
// this
char strBuffer[33];
// change to this
uint16_t GaugingStatus;
you are not changing one pointer for another, you are changing a pointer for a variable. You need to get the pointer to that variable and then "disguise" the uint16_t* pointer as a char* pointer via type casting.
Hence this should build without error
bms.GaugingStatus((char*)&GaugingStatus);
But for better coding style and integrity of memory you may well want to change something in the library.
I'd start with changing the name of readStringB() to something like readBytes() and put back that int len paramter you had in post #70 - you will need that for data integrity.
So make it readBytes(uint8_t address, void* buffer, int len) since you are not only getting strings and will not only get char back and depending on the address you should know how many bytes to read. And only read that many bytes into the target.
If you get a different length than you expected this is an error condition and should be treated and signalled as such (read and drop extra bytes to keep the bus tidy - mark too short or too long with return -receivedLength).
Don't add any zero-terminator in that function but only in a higher level function that knows the requested address will in fact return a string which requires termination.
Change any of your existing higher level functions like this
//int BQ20Z45::GaugingStatus(char *result)
// return readStringB(BQ20Z45_GaugingStatus, result);
int BQ20Z45::GaugingStatus(uint16_t* result)
return readBytes(BQ20Z45_GaugingStatus, (void*)result, 2);
// for platforms with incompatible endianness you may want to
// add some code to correct the byte order
I went over this for hours and I think I have modified the function as you recommended to make it more efficient.
Below is the new function, take a look and let me know if it’s what you had in mind
I also question if in the first line where it says: void* buffer, should it be void* result instead?
int BQ20Z45::readBytes(uint8_t address, void* buffer, int len)
int pos = 0;
//int len;
Wire.requestFrom(BQ20Z45_Address, len, true); //Setup Reading of Returned Data
Wire.read(); //We will call 3 Wire.Reads and nto use them since they contain
Wire.read(); //the returned data length, and address that is returning data
Wire.read(); //which we do not want included in the returned data string.
//result[pos] = '\0'; // append the zero terminator
return len;
And then as you already modified this will call that function:
Now I know I need to add this function to the Class line up in the .H file as shown below but I’m not really sure what to replace the char* result with that’s currently being used in
int readStringB(uint8_t address, char* result);
When I try to compile the new code in the .cpp file I get this compile error because the function is not properly added to the Private section of the .H file.
I tried adding int readBytes(uint8_t address, void* result, int), but that didn’t help
Thanks for your help with this! I’d be lost without your help for sure
This would be what I had in mind (during implementation I felt the need for an extra flag)
// .h
int readBytes(uint8_t address, void* buffer, size_t len, boolean exactLen = true);
// .cpp
int BQ20Z45::readBytes(uint8_t address, void* buffer, size_t len, boolean exactLen)
int pos;
int cnt; // to hold the actual length the address would hold
cnt = Wire.read(); // length of the string thats about to return
cnt++; // plus one to allow for the length byte on the reread
cnt = Wire.requestFrom(BQ20Z45_Address, cnt, true); // readRequest returns # bytes actually read
if (cnt == len+3 || !exactLen && cnt > 3)
{ // we got the expected read count
cnt -= 3; // drop the first three bytes
Wire.read(); // length received lsb
Wire.read(); // length received msb (always 0) ???
Wire.read(); // address from which we just read
memset(buffer, 0, len); // clear the buffer for safe measure
for (pos = 0; pos < cnt; pos++)
if (pos < len) buffer[pos] = Wire.read(); // as long we have room in the buffer add to it
else Wire.read(); // otherwise just drop it
return cnt;
else
{ // drop them all
for(pos = 0; pos < cnt; cnt++)
Wire.read();
return -cnt; // includes the extra three bytes
Is this comma , at the end there a typo? Shouldn't that be a semi-colon ;?
And for ease of coding you can modify the high level functions this way to keep the len parameter consistent with the datatype
return readBytes(BQ20Z45_GaugingStatus, (void*)result, sizeof(*result));
Thanks for that I added your modified code to the library and all is good except for one minor thing that I can’t seem to figure out yet and I kinda feel like an idiot because of it.
I’ve tried about 10 different combinations of different codes but none of them compile which leads me to believe that I must now understand what is going on although I feel I do.
I need to change the class variable here:
It’s this line that is causing the complie errow below:
I’ll spare you all the code that I tried that didn’t work but some guidance is appreciated as usual.
Isn’t this the function signature int BQ20Z45::GaugingStatus(uint16_t* result) and hence the header should have int GaugingStatus(uint16_t* result);?
The error message is quite explicit.
It complains about a non-exixtent definition for that function that takes a uint16_t* and that’s true, since you only have one that takes a char*.
BQ20Z45 bms;
void setup(void)
Wire.begin();
void loop(void)
//Serial.print("Device Name: ");
bms.GaugingStatus(result);
delay(4000);
The .CPP :
// Functions Below
// Fuel gague function to read Manufacturer Access Data registers when in sealed mode.
int pos;
return cnt;
else
{ // drop them all
Wire.read();
int BQ20Z45::GaugingStatus(uint16_t* result) //int BQ20Z45::GaugingStatus(char *result)
That was a long road to travel, but it's working now Feels good
THANK YOU SO MUCH FOR HELPING ME WITH THIS!
@Ric Thanks for that tip also! One less than I had to ask ScruffR for help with, which is nice
I would have figured out to add the GaugingStatus but adding the & sign in front of it is something I have not fully grasped yet, although @ScruffR did mention this to me in a post above:
And the more important point IMHO is not the success but the insight you gained on the way
The success is one benefit, but the lessons learnt will benefit you over and over when you run into similar questions.
Give a starving man a fish or teach him how to fish.
I have one command that is returning 34 bytes of data and I’m saving that in a StrBuffer that is sized to 34 bytes in size so it can actually hold that much data. Even though I increased the buffer size I now see that the Wire.RequestFrom function is coded to max out to only return 32 bytes max.
