I need to grab the status of a push button from BLYNK and use the variable inside the LOOP() to pass to other function calls.
I made a very short test program to duplicate what I’m getting in a much larger program as follows:
#include "blynk/blynk.h"
char BlynkToken[] = "70a54d197825483c9c00ee99999a234e";// bogus number
int pinData = 0;
Blynk.begin(BlynkToken);
delay(5000); // Allow time to stabilize
//xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Blynk.run();
BLYNK_READ(V0) // Get and store push button status
int pinData = param.asInt(); // save status
I get an error message "function definition is not allowed here before “{” token
void^ loop()
Yup, as @peekay123 said.
You’ve already got a global pinData, so drop the data type (int) inside the BLYNK_READ() implementation otherwise you just hide the global variable and will lose the assigned value once the local pinData goes out of scope.
i rewrote the test program as follows which compiles, but I’m not sure if I use Blynk.virtualWrite(v5, pinData) to GET and SET the status from/to the Android push button widget --CONFUSED
Is my BLYNK_WRITE function definition the best way to retrieve and set pinData?
int pinData = 0; // global variable
BLYNK_WRITE(V5) //Button Widget is writing to pin V5
if (param.asInt())
pinData = 1;
else
pinData = 0;
Blynk.run();
Blynk.virtualWrite(v5, pinData) // update the state of the Button Widget in the app
Discovered, I’m not really using BLYNK_WRITE(V5), just passing the value of the global variable =0 every time.
If I try to use the function call inside loop() it fails. Again confused on how to used this function.
Blynk.run();
BLYNK_WRITE();
Blynk.virtualWrite(V5, pinData) // update the state of the Button Widget in the app
junk1.cpp: In function 'void loop()':
junk1.cpp:32:1: error: expected ';' before '}' token
make[1]: *** [../build/target/user/platform-6junk1.o] Error 1
make: *** [user] Error 2
Ah yes, I changed horses didn’t I? Okay I inserted the “;” and the test program compiled.
But, If I don’t use the BLYNK_WRITE function, how will I know the status of the push button on the Blynk App to be able to change pinData from 1 or 0 and notify the app of the changes I make?
This is why I started with BLYNK_READ. I thought I needed to first GET the status of the button, then I could do a BLYNK_WRITE to send back to the APP. Am I making this too difficult?
Blynk.virtualWrite() does the writing (from Photon to Blynk app), while BLYNK_WRITE() is the function that gets called (from inside Blynk.run()) when the Blynk app wants to set (write to) the virtual pin on the Photon.
The capitalised “functions” are some kind of callback function where you put your code what should happen when the phone app wants to READ or WRITE data from or to the Photon.
On the other hand, you’d use Blynk.virtualWrite() when your Photon code wants to write to the virtual pin on the phone app.
So you’d need to distinguish between the phone app view and the Photon view when choosing to read or write (READ on one side means write on the other side ).
Thank you for clarification, I have been studying BLYNK documentation and have yet to find a useful solution. Can you review this simple TEST program to help me understand how to work with BLYNK and the PHOTON as explained in my comments inside the code. THANK YOU
#define ON 255
#define OFF 0
int pinData = ON; // change this global variable to prove code is functioning
long prevMillis = 0;
long interval = 100;
bool isFirstConnect = true;
char BlynkToken[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
delay(5000); // give time to settle
BLYNK_CONNECTED() // runs every time Blynk connection is established
if (isFirstConnect)
// Request server to re-send latest values for all pins
Blynk.syncAll();
isFirstConnect = false;
BLYNK_READ(V0) //Function to get status of BLYNK widget from Android ??
Blynk.virtualWrite(V0,pinData); // is this the correct statement ??
// what code can be entered here to receive info from the push button?
// the following statement to is to prove the READ function wss executed
Particle.publish("BLYNK_READ executed : ", String(pinData));
//xxxxxxxxxxxx[ Widget Button using virtual pin # 0 ]xxxxxxxxxxx
BLYNK_WRITE(V0) //Function to send status to BLYNK widget from PHOTON ??
int state = param.asInt();
if (state)
Blynk.virtualWrite(V5, ON);
// what code can be entered here to send or receive info from the push button?
// the following statement is to prove the WRITE function was executed
Particle.publish("BLYNK_WRITE executed : ", String(ON));
else
Blynk.virtualWrite(V5, OFF);
Particle.publish("BLYNK_WRITE executed : ", String(OFF));
Blynk.run();
// checkIfWorking(); // call to see if BLYNK is responding if needed
void checkIfWorking() // this is just to comfort me that BLYNK is still responding
unsigned long curntMillis = millis();
if( curntMillis - prevMillis > interval)
prevMillis = curntMillis;
Blynk.virtualWrite(V3, pinData); // virtual LED
Particle.publish("Data value of pinData: ", String(pinData));
I'd not put a publish in there since this function will be called each time the blynk app wants to read the virtual pin state from Photon and this can be (depending on your V0 setting in the app) more frequently than allowed by the publishing limit (once per sec) - especially if you have multiple V-pins doing the same.
Otherwise you put all the code in here that's required to gather the values toghter you'd need to send back to the mobile app via virtualWrite().
Not quite, this reads from the Photon to update the widget in the mobile app.
The same here, use publish with caution.
Otherwise you'd put the code here to catch the data sent from the mobile app (e.g. via param.as...()) and do whatever is required to control the Photon's behaviour as intended.
Again, as with BLYNK_READ()and said earlier
not the other way round!
And as a rule of thumb, try to reduce the code in these functions to the required minimum and off-load more laborious tasks to loop() (e.g. by setting flags to be checked in loop()).
SOLVED! A great big THANK YOU to the Particle and Blynk Communities, I have a good working example showing how to use a BLYNK Push Button. The BLYNK push button shows its state,ON or OFF when used as a switch. I also write to a BLYNK LED to give show the subroutines executed by toggling a virtual LED. I publish the variable value for displaying the intensity of a virtual LED to the Particle Dashboard. When the PB is toggled is will display either 0 or 255 (255 = full on for virtual LED). I used #define for ON = 255 and OFF = 0. I’m not entirely sure if I’m flooding the servers, so I welcome comment on how to control it. Below is my TEST APP.
// if not displayed in this example, be sure to include '#' before include and define
#define ON 255
#define OFF 0
char BlynkToken[] = "999999999999999999999999999999"; // insert your Blynk token here
if (isFirstConnect)
Blynk.syncAll();
//xxxxxxxxxxxx[ Push Button Widget using virtual pin V0 ]xxxxxxxxxxx
BLYNK_WRITE(V0) //Function to test status from BLYNK widget to PHOTON
if (state ==1)
TurnOn();
else if (state ==0)
TurnOff();
Blynk.run();
void TurnOn()
Blynk.virtualWrite(V7, ON); // virtual LED
Particle.publish("TurnOn state executed : ", String(ON));
void TurnOff()
Blynk.virtualWrite(V7, OFF); // virtual LED
Particle.publish("TurnOff state executed : ", String(OFF));
