Use indexOf() on an int-array instead of a string
Is there a way to use indexOf on an int-array instead of a string? I have an int array of hours (non-regular) at which I want to perform an action.
int hourReset[]={0,6,12,20};
if(hourReset.indexOf(Time.hour()) > -1 && Time.hour() != lastReset){
        lastReset = Time.hour();
        Particle.publish("I MUST SLEEP!");
        System.sleep(SLEEP_MODE_DEEP, 15);
Sorry. In C/C++ the int is a simple built-in type and not a class. Therefore there are no methods that you can call on an instance. You will have to traverse the array the hard way to find your index.
Sad. But thanks for the quick reply.
@eric.spaeth, here is a simple solution from StackOverflow:
First its important that the argument list contain size information for the array, i.e. passing a pointer to an array only does not provide enough information to know how many elements the array has. The argument decays into a pointer type with no size information to the function.
So given that, you could do something like this:
int findIndex(int *array, size_t size, int target)
    int i=0;
    while((i<size) && (array[i] != target)) i++;
    return (i<size) ? (i) : (-1);
For small arrays this approach will be fine. For very large arrays, some sorting and a binary search would improve performance
