Usage fault with i2c bus wire and wire1 endTransmission
I am having problems using a humidity sensor SHT31-D with wire and wire1. I stripped out code from the Adafruit_SHT31 library and to find the issue and it works great with arduino. Whenever endTransmission is called, it puts the Electron into a usage fault (5 flashes). Problem on both wire and wire1 pins.
I want to use wire1 (pins C4 & c5) so I set SLC pin to INPUT as discussed.
I checked for DIV/0 by printing all the wite() commands.
I have the pull-up resistors as discussed.
Code -
void writeCommand(uint16_t cmd) {
  Serial.println("writeCommand input cmd = ");
  Serial.println(cmd);
  delay(100);
  Wire1.beginTransmission(0x44);
  Serial.println("writeCommand cmd >> 8");
  Serial.println(cmd >> 8);
  delay(100);
  Wire1.write(cmd >> 8);
  Serial.println("writeCommand cmd & 0xFF");
  Serial.println(cmd & 0xFF);
  delay(100);
  Wire1.write(cmd & 0xFF);
  Serial.println("writeCommand end Transmission");
  delay(100);
  Wire1.endTransmission();
  Serial.println("writeCommand Done");
  delay(100);
void setup(){
  Serial.begin(9600); // connect serial
  pinMode(C5, INPUT);
  delay(10000); //so I have time to start serial monitor
  writeCommand(0x30A2); ///SHT31_SOFTRESET);
  delay(10);
bool CheckHumidity(float &hum){
  Serial.println("Here 1");
  delay(100);
  writeCommand(0x2400); ///SHT31_MEAS_HIGHREP
  uint8_t readbuffer[6];
  Serial.println("Here 2");
  delay(100);
  Wire1.requestFrom(0x44, (uint8_t)6); //(_i2caddr,
  if (Wire1.available() != 6)
    return false;
  for (uint8_t i=0; i<6; i++) {
    readbuffer[i] = Wire1.read();
  uint16_t SRH;
  SRH = readbuffer[3];
  SRH <<= 8;
  SRH |= readbuffer[4];
  Serial.println("Here 3");
  delay(100);
  uint8_t *data = readbuffer+3;
  int len = 2;
  const uint8_t POLYNOMIAL(0x31);
  uint8_t crc(0xFF);
  for ( int j = len; j; --j ) {
      crc ^= *data++;
  for ( int i = 8; i; --i ) {
    crc = ( crc & 0x80 )
      ? (crc << 1) ^ POLYNOMIAL
      : (crc << 1);
  Serial.println("Here 4");
  delay(100);
  if (readbuffer[5] != crc) return false;
  double shum = SRH;
  shum *= 100;
  shum /= 0xFFFF;
  hum = shum;
  Serial.print("humidity = ");
  Serial.println(hum);
  return true;
void loop(){
  float curHum = 0.0;
  CheckHumidity(curHum);
  Serial.println(curHum);
  delay(1000);
I might be blind, but where are your Wire.begin() or `Wire1.begin() calls?
Also what system version are you targeting?
Here is a working library for the SHT31D sensor.
Why are you putting these huge delays between the .write()'s? .write() just caches bytes until the endTransmission() call, which is what sends the message.
Thanks, that was it I was missing the lost the Wire.begin when I stripped the code. I was missing the pinMode(C5, INPUT); before I stripped it all.
The delays are because on one of them aruino or particle, I have had the last serial.print not show up if it something goes wrong really fast after it.
