I am storing a bunch of dummy objects in an unordered_map, and then iterating through to delete them. Somehow, it comes out with a key value pairing where the value is a null pointer, even though I'm pretty sure that is not possible.
Each of the objects that I make just houses a part of a very large string that I construct randomly. I make sure to hand the constructor of this object at least 5 characters of the string.
Here is the code:
Delete Function
bool delete_objects(){
Serial.println("deleting objects in 'store'");
for(auto iter = store.begin(); iter != store.end(); iter++)
Serial.println("\nDeleting the following element: \n");
Serial.print("Key: ");
Serial.println(iter->first);
delay(1000);
Serial.print("Value: ");
Serial.println(iter->second->ShowMeWhatYouGot());
delay(1000);
delete iter->second;
iter->second = nullptr;
store.erase(iter);
if(store.empty())
return true;
else
return false;
block where objects are allocated (delete_objects() is called right before this)
unsigned int index = 0;
unsigned int key = 0;
while(index < buff_string.length()){
int amount = (rand() % 51) + 5;
DummyClass* dc = new DummyClass(buff_string.substring(index, index + amount));
store[key] = dc;
index += amount;
key++;
Serial.println("Created new DummyClass object");
Serial.print("Free Memory: ");
Serial.println(System.freeMemory());
class definition
using namespace std;
class DummyClass {
private:
char* _container;
public:
DummyClass(){
DummyClass(String input){
_container = new char[input.length()];
strcpy(_container, input.c_str());
~DummyClass(){
delete _container;
_container = nullptr;
char* ShowMeWhatYouGot(){
return _container;
Serial Output, it SOS's when key is 0
Key: 194
Value: q->@B{s?tX/miN3K?[~2[mvTOSKPE34#5[@q8*d8BZwH`
Key: 193
Value: 9Hb^7-J(#z3H#0uqg
Key: 192
Value: V$xZ>C$u{MjxzxL?{KQqvQp*MN3~Ce&yZbmop1$9xlkJM)jGja~P{mY
Key: 191
Value: yo*CVzE~2
Key: 190
Value: [&PQakTV3{^Aq?(ffV/*24xaXej]~T1^SfWiM3ATpk#{CoQ
Key: 0
Value:
