Hi, I’m using a Photon with a BME280 sensor to send weather readings to an Azure IoT Hub using the particle integration, but I’m struggling to figure out this ‘slash’ issue.
I have this code:
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define BME_SCK D4
#define BME_MISO D3
#define BME_MOSI D2
#define BME_CS D5
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK);
unsigned long delayTime;
float temperature = 0;
float pressure = 0;
float humidity = 0;
char buf[256];
Serial.begin(9600); //initiate serial monitor and set data transfer rate
bme.begin(); //initiate the sensor
delayTime = 10000; //set delay to 10 seconds
//take sensor readings
temperature = bme.readTemperature();
pressure = bme.readPressure() / 100.0F;
humidity = bme.readHumidity();
//clear JSON buffer
memset(buf, 0, sizeof(buf));
JSONBufferWriter writer(buf, sizeof(buf) - 1);
//write readings as JSON
writer.beginObject();
writer.name("Temperature C").value(temperature);
writer.name("Pressure hPa").value(pressure);
writer.name("Humidity %").value(humidity);
writer.endObject();
//print JSON buffer to serial monitor
Serial.println(buf);
Serial.println();
//publish readings to Azure
Particle.publish("SendToAzure", buf, PRIVATE);
//wait some time
delay(delayTime);
which is successfully creating valid JSON:
but when I check the events arriving in the IoT Hub the key string has gained a slash before each double quote:
I’m a bit new to this so not entirely sure how to resolve my code to generate valid JSON in Azure (i.e. without the slashes). Any pointers will be much appreciated!
db
