@mtnscott the worst thing is the hard reset each time I flash the core with a new delay (1 sec to 15 sec no differences).
I’m looking forward to your test, thank you.
Hi @mtnscott,
We’re getting ready to release webhooks at the end of the sprint, which will let the Spark Cloud make a request for you to some service or app when you publish an event from your core(s), which should make it easier to store and react to events from your core.
David
So @Dave it’s not possible to do both currently?
I’ll wait for the end of the sprint!
I was re-reading your code above–it is really “Delay()” with a capital-D? The Wiring function in Spark is lower-case-D “delay()”. What happens when you change to “delay(1000);”?
Having both Spark.variables() and Spark.publish() is definitely possible!
Hi @Barabba,
I’m not sure what you mean? Do you mean performing a POST request from the core itself while also publishing events? I think that should be possible, but it’s certainly easier to use something like a webhook for certain kinds of requests, especially when you’re hitting a https service.
David
@Barabba - I was able to get this up and running in google drives with a spreadsheet polling the Spark variable every minute. It has been up and running for 10 mins and I have not experience any problems.
@Dave - webhooks sounds great. Can’t wait to test and learn more!
Exactly POST or GET requests while publishing. But webhooks could be definitely a killer feature!
@bko - It’s working! Lower case delay was the solution, but why is it possible to call Delay without compile errors? Now I’m publishing every 5 seconds sending GET requests without any kind of connection loss.
Thank you everybody.
Hi @Barabba
Glad to hear it is working now!
I opened a github issue so the team can try prevent this type of thing in the future:
