The Logger is providing some great feedback in debugging my application, but I am running into an odd issue:
I’m using SerialLogHandler logHandler(LOG_LEVEL_ALL);
with the Logger class to trace program flow, but mylog.info("Button event fired!");
does not seem to work from inside an event handler registered with System.on(..
Serial.println("Button event fired!");
still works fine from within the event handler, but the log NEVER produces output. It doesn’t seem to be suppressed anywhere else.
I don’t have a ton of time to make a test example to submit a bug report right this second, but I wanted to put a feeler out and see if anyone has noticed this before. I’ll try to get around to it later if it hasn’t been reported.
