With a directory structure like this
src
- main.ino
- sub
- lib1.h
- sub2 symlinked
- lib2.h
where sub2 is a directory symlink to a directory outside of the project directory. I can include sub/lib1.h fine, but /sub2/lib2.h does not include. The cloud compiler gives
fatal error: sub2/lib2.h: No such file or directory
and sub2/lib2.h does not appear in the list of included files. Presumably the symlinked directory is not being uploaded properly? This compiles fine with the local compiler. If I use the lib
directory I get the same problem.
Perhaps I am approaching this wrong and symlinks are not the best idea - when having multiple projects that all need to share some common code, what’s the best way to include one common file in all the projects?
