@peekay123 Here is the code, it’s for testing the RFM95 radio modules:
//PHOTON
// this the client running on photon
#include <RHReliableDatagram.h>
#include <RH_RF95.h>
//#include <SPI.h>
SYSTEM_MODE(SEMI_AUTOMATIC);
#define CLIENT_ADDRESS 1
#define SERVER_ADDRESS 2
const int ledPin = D7; // D7 has an LED
// Singleton instance of the radio driver
RH_RF95 driver; //(A2,D2)-->you don't nee set this
//RH_RF95 rf95(5, 2); // Rocket Scream Mini Ultra Pro with the RFM95W
// Class to manage message delivery and receipt, using the driver declared above
RHReliableDatagram manager(driver, CLIENT_ADDRESS);
// Need this on Arduino Zero with SerialUSB port (eg RocketScream Mini Ultra Pro)
//#define Serial SerialUSB
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
if (!manager.init())
Serial.println("init failed");
driver.setTxPower(23, false);
driver.setFrequency(915.0); // hay que setear frecuencia para los rfm96 915
delay(5000);
Serial.println("..this is the Photon as Client Radio");
//uint8_t data[] = "Hello World # ";
// Dont put this on the stack:
uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
int32_t packetnum = 0; // packet counter, we increment per xmission
Serial.println("Sending to Server Base Station");
// Send a message to manager_server basestation.
char radiopacket[20] = "Hello World # ";
itoa(packetnum++, radiopacket+13, 10);
Serial.print("Transmitting > "); Serial.println(radiopacket);
radiopacket[19] = 0;
Serial.println("");
if (manager.sendtoWait((uint8_t *)radiopacket, sizeof(radiopacket), SERVER_ADDRESS))
// Now wait for a reply from the server base station.
uint8_t len = sizeof(buf);
uint8_t from;
Serial.println("Waiting for reply..."); delay(10);
if (manager.recvfromAckTimeout(buf, &len, 2000, &from))
//Flash D7 LED on Photon if Received Reply
digitalWrite(ledPin, HIGH);
delay(500);
Serial.print("Got reply from Server Base Station 0x");
Serial.print(from, HEX);
Serial.print(": ");
Serial.println((char*)buf);
Serial.print("RSSI: ");
Serial.println(driver.lastRssi(), DEC);
Serial.println();
Serial.println();
else
Serial.println("No reply from Server Base Station?");
//Flash D7 LED on Photon if No Reply From Server Base Station.
delay(200);
delay(200);
delay(200);
else{
Serial.println("sendtoWait failed");
digitalWrite(ledPin, HIGH); //Flash D7 LED on Photon if SendtoWait Failed
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(5000);
I’m specifically talking about this variable that was int16_t:
@ScruffR I was wrong about it being a uint16_t , its a int16_t instead
Does the int16_t just roll over also?
If it goes negative then that may be the cause of the lock up.
Haven’t looked to far into this yet.
