When I set SYSTEM_MODE to SEMI_AUTOMATIC or MANUAL, the UDP.parsePacket() always returns 0. When I check WiFi.ready() it returns true, this means it is connected to WiFi and has an IP assigned. I am sending the UDP packet from the same network, so even if Spark Core is not connect to Cloud, the UDP should work, is it? But it is not when I set the SYSTEM_MODE other than AUTOMATIC. What I want is that my Spark Core does not want to connect to Cloud but it should receive UDP packets from local network.
My actual code is not this but, for debugging purpose I am using the following code from Spark Core documentation.
#include "application.h"
SYSTEM_MODE(SEMI_AUTOMATIC);
// UDP Port used for two way communication
unsigned int localPort = 8888;
// An UDP instance to let us send and receive packets over UDP
UDP Udp;
// start the UDP
Udp.begin(localPort);
// Print your device IP Address via serial
int packets = Udp.parsePacket();
Serial.print("Parse Packet returned ");
Serial.print(packets);
Serial.print(", WiFi Status ");
Serial.println(WiFi.ready());
// Check if data has been received
if (packets > 0) {
// Read first char of data received
char c = Udp.read();
// Ignore other chars
Udp.flush();
// Store sender ip and port
IPAddress ipAddress = Udp.remoteIP();
int port = Udp.remotePort();
// Echo back data to sender
Udp.beginPacket(ipAddress, port);
Udp.write(c);
Udp.endPacket();
I added Serial.print for debugging purpose, am I missing something here?
UPDATE #1: The code is working when you move UDP.begin() inside the loop() method. Following code works, I should have tried this before posting here
if(WiFi.ready() && !isInitialized ){
// start the UDP
isInitialized = true;
UPDATE #2: For MANUAL mode, you should call WiFi.connect()
