hello we have a query regarding the uart. is there any global typdef where we can declare pointer of that type and later assign uart something like
Stream uart;
int port = 0;
switch(port){
case 1:
uart = Serial1;
case 2:
uart = Serial2;
since we are using couple of sensors with interchangable uart the problem is with uart we don’t want to hardcode uart
thank you
Serial1 and Serial2 are of type USARTSerial
But you would not want to do something like this
USARTSerial uart = Serial1;
but rather
USARTSerial *uart = &Serial1;
Or if you can opt for a reference
USARTSerial& uart = Serial1;
This is especially suitable for a sensor class where you pass the respective interface to use to the constructor.
