Two sensors DHT22 and Argon
Hello
I have an Argon and I connected 2 DHT22 sensors I use the Pittetech Library and the example DHT_2sensor.ino I just replaced the sensor type from DHT11 to DHT22 in the example.
#define DHTTYPEA  DHT22       // Sensor type DHT11/21/22/AM2301/AM2302
#define DHTPINA   D3          // Digital pin for comunications
#define DHTTYPEB  DHT22       // Sensor type DHT11/21/22/AM2301/AM2302
#define DHTPINB   D2          // Digital pin for comunications
Unfortunately, if I connect 2 sensors, I get a time out error on the putty. This does not happen if I use from the same library the example DHT_simple.ino and connect only one sensor.
Does anyone have an idea how to correct it so that they can use the two sensors?
Thanks Valentino
Output from Putty
0 : 0.00s, Retrieving information from sensor: Read sensor A: Error
        Data time out error
Humidity (%): -4.00
Temperature (oC): -4.00
0 : 0.00s, Retrieving information from sensor: Read sensor B: Error
        Data time out error
Humidity (%): -4.00
Post some compilable code - this make it much easier for folks to help you
Hi shanevanj this is the code copy from the library(DHT_2sensor.ino) in WEBIDE I change only this line with the DHT22 sensors:
*** #define DHTTYPEB DHT11
Thanks for your answer and help
Valentino
 * FILE:        DHT_2sensor.cpp
 * VERSION:     0.4
 * PURPOSE:     Example that uses DHT library with two sensors
 * LICENSE:     GPL v3 (http://www.gnu.org/licenses/gpl.html)
 * Calls acquire on two sensors and monitors the results for long term
 * analysis.  It uses DHT.acquire and DHT.acquiring
 * Also keeps track of the time to complete the acquire and tracks errors
 * Scott Piette (Piette Technologies) scott.piette@gmail.com
 *      January 2014        Original Spark Port
 *      October 2014        Added support for DHT21/22 sensors
 *                          Improved timing, moved FP math out of ISR
 *      September 2016      Updated for Particle and removed dependency
 *                          on callback_wrapper.  Use of callback_wrapper
 *                          is still for backward compatibility but not used
 * ScruffR
 *      February 2017       Migrated for Libraries 2.0
 *                          Fixed blocking acquireAndWait()
 *                          and previously ignored timeout setting
 *                          Added timeout when waiting for Serial input
 *                          Fixed possible cloud drop with faulty sensor
 * With this library connect the DHT sensor to the following pins
 * Spark Core: D0, D1, D2, D3, D4, A0, A1, A3, A5, A6, A7
 * Particle  : any Pin but D0 & A5
 * See docs for more background
 *   https://docs.particle.io/reference/firmware/photon/#attachinterrupt-
 // NOTE DHT_REPORT_TIMING requires DHT_DEBUG_TIMING in PietteTech_DHT.h for debugging edge->edge timings
 //#define DHT_REPORT_TIMING
#include "PietteTech_DHT.h"
#define DHTTYPEB  DHT11       // Sensor type DHT11/21/22/AM2301/AM2302
// Instantiate two class objects
PietteTech_DHT DHTA(DHTPINA, DHTTYPEA);
PietteTech_DHT DHTB(DHTPINB, DHTTYPEB);
int n;      // counter
#define LOOP_DELAY 5000 // 5s intervals
int _sensorA_error_count;
int _sensorB_error_count;
int _spark_error_count;
unsigned long _lastTimeInLoop;
  while (!Serial.available() && millis() < 30000) {
    Serial.println("Press any key to start.");
    Particle.process();
    delay(1000);
  Serial.println("DHT 2 Sensor program using DHT.acquire and DHT.aquiring");
  Serial.print("LIB version: ");
  Serial.println(DHTLIB_VERSION);
  Serial.println("---------------");
  DHTA.begin();
  DHTB.begin();
  delay(1000);        // Delay 1s to let the sensors settle
  _lastTimeInLoop = millis();
#if defined(DHT_REPORT_TIMING)
// This function will report the timings collected
void printEdgeTiming(class PietteTech_DHT *_d) {
  byte n;
  volatile uint8_t *_e = &_d->_edges[0];
  Serial.print("Edge timing = ");
  for (n = 0; n < 41; n++) {
    Serial.print(*_e++);
    if (n < 40)
      Serial.print(".");
  Serial.print("\n\r");
#endif
void printSensorData(class PietteTech_DHT *_d) {
  int result = _d->getStatus();
  if (result != DHTLIB_OK)
    if (_d == &DHTA)
      _sensorA_error_count++;
    else
      _sensorB_error_count++;
  switch (result) {
  case DHTLIB_OK:
    Serial.println("OK");
    break;
  case DHTLIB_ERROR_CHECKSUM:
    Serial.println("Error\n\r\tChecksum error");
    break;
  case DHTLIB_ERROR_ISR_TIMEOUT:
    Serial.println("Error\n\r\tISR time out error");
    break;
  case DHTLIB_ERROR_RESPONSE_TIMEOUT:
    Serial.println("Error\n\r\tResponse time out error");
    break;
  case DHTLIB_ERROR_DATA_TIMEOUT:
    Serial.println("Error\n\r\tData time out error");
    break;
  case DHTLIB_ERROR_ACQUIRING:
    Serial.println("Error\n\r\tAcquiring");
    break;
  case DHTLIB_ERROR_DELTA:
    Serial.println("Error\n\r\tDelta time to small");
    break;
  case DHTLIB_ERROR_NOTSTARTED:
    Serial.println("Error\n\r\tNot started");
    break;
  default:
    Serial.println("Unknown error");
    break;
  // print debug timing information
  printEdgeTiming(_d);
#endif
  Serial.print("Humidity (%): ");
  Serial.println(_d->getHumidity(), 2);
  Serial.print("Temperature (oC): ");
  Serial.println(_d->getCelsius(), 2);
  Serial.print("Temperature (oF): ");
  Serial.println(_d->getFahrenheit(), 2);
  Serial.print("Temperature (K): ");
  Serial.println(_d->getKelvin(), 2);
  Serial.print("Dew Point (oC): ");
  Serial.println(_d->getDewPoint());
  Serial.print("Dew Point Slow (oC): ");
  Serial.println(_d->getDewPointSlow());
  unsigned long _us = millis();
  unsigned long _delta = (_us - _lastTimeInLoop);
  if (_delta > (1.05 * LOOP_DELAY))
    _spark_error_count++;
  // Launch the acquisition on the two sensors
  DHTA.acquire();
  DHTB.acquire();
  // Print information for Sensor A
  Serial.print("\n");
  Serial.print(n);
  Serial.print(" : ");
  Serial.print((float)(_delta / 1000.0));
  Serial.print("s");
  if (_sensorA_error_count > 0 || _spark_error_count > 0) {
    Serial.print(" : E=");
    Serial.print(_sensorA_error_count);
    Serial.print("/");
    Serial.print(_spark_error_count);
  Serial.print(", Retrieving information from sensor: ");
  Serial.print("Read sensor A: ");
  while (DHTA.acquiring()) Particle.process();
  printSensorData(&DHTA);
  // Print information for Sensor B
  Serial.print("\n");
  Serial.print(n);
  Serial.print("s");
  if (_sensorB_error_count > 0 || _spark_error_count > 0) {
    Serial.print(_sensorB_error_count);
    Serial.print("/");
  Serial.print("Read sensor B: ");
  while (DHTB.acquiring()) Particle.process();
  printSensorData(&DHTB);
  n++;
  _lastTimeInLoop = _us;
  delay(LOOP_DELAY);
Hi shenevanj
I change library, I use Adafruit-library(Adafruit_DHT.h) and I modify the my firmware .
Thanks Valentino
