Troubleshooting Email from Core
Had done this already. The code is located in a .cpp file and #include “application.h” as indicated.
Strange is : this code was working and stop working after I changed code in other files. So, nothing had changed in the “SendEmail” function which will communicate to the URL.
Additional test being done on a Test Apps which only has the ino file and no other library attached. Make the TCPClient connect call in the “Setup()” and also failed :frowning:
OK, found a workaround. If I use the IP address directly, then it OK.
byte serverIP = { 213, 186, 33, 19 }; // pushing box
client.connect(serverIP, 80) --> OK
client.connect("api.pushingbox.com", 80) --> NO GOOD
Anyone has idea ?
It sounds like DNS service from your router is not working. Are other hosts on your network having any trouble with domain names?
I have the same issue frequently… thats the exact reason why i ported this
but it will give you an error now, it needs updating… ill fix it tomorrow… but the fix is here if you need it sooner!
That is really cool and great for your satellite (I think) Internet link, but shouldn’t be needed by everyone. If you have a regular broadband connection, you should be able to use the built-in DNS client.
i have some days on the home internet where it cant look-up, and that’s on 100mbit cable… not all the time and if you wait 5 mins it will work again. but yep your right on the slow satellite it never works
The strange thing is : the same address was working before. So, the router DNS lookup should be OK, I think. I did not experience other device having any problem. I am using my PC to lookup the IP address for the site.
One more strange error I am having is :frowning: I am trying to access the weather site
api.wunderground.com
serverIP = { 23, 195, 210, 80 };
I had validated this with the PuTTY and response is OK
GET /api/my ID/conditions/q/autoip.json HTTP/1.1
Host: api.wunderground.com
HTTP/1.1 200 OK
Server: Apache/1.3.42 (Unix) PHP/5.3.2
But when I use the SpareCore to communicate, it did not work....
HTTP/1.1 400 Bad Request
Server: AkamaiGHost
Mime-Version: 1.0
Hi @Dilbert
The response from AkamaiGHost indicates that this in an edge router, that is, Akamai is providing a sort of caching service for the host api.wunderground.com. You really, really need the Host: line in your HTTP request since that is the only way the edge router knows what host you actually wanted to talk to.
So I would check that your HTTP request has a valid Host: line.
Hi Brian,
Thanks for direction :slight_smile: Once again it is the line format issue.
  1. "\n\r" --> not working
  2. "\r\n" --> OK
I used the 1st format in the PushingBox.com is fine. But this one is not. I am a newbie to all the TCP IP stuff. How would I know which format each server will support ? Or the standard is using the 2nd one ??
remaining issue to solve is why DNS lookup not working...
Since I am using the online build option, how could I update your change in DNSClient.cpp ??
@Dilbert I have updated the files on Git today, they can be manually added as a library
To give you an idea of what its doing, it takes the serverName, connects to Google’s DNS, resolves the IP, and returns the IP into remote_addr. your function then uses remote_addr to pass to the TCPclient. because its already an IP address it doesn’t need to look it up.
in the online build page you can add tabs, there is a little plus up the top right. you will need to create a set of tabs (it adds *.cpp and *.h) name them “DNSclient” then add another set of tabs and call them “myUDP” once thats done you can delete just the “myUDP.cpp” as you don’t need it.
in the Git page linked to above there are 3 folders… example, inc and src. Copy and paste the text from DNSclient.cpp in the src folder into your new tab with the same name. then do the same for “DNSclient.h” and “myUDP.h” in the inc folder
When you add the tabs it will automatically add two lines -> “#include DNSclient.h” and “#include myUDP.h” you need to delete just the “#include myUDP.h” the other one is needed
Before the setup function you need to add:
IPAddress dnsServerIP(8,8,8,8);
IPAddress remote_addr;
DNSClient dns;
At the top of your SendEmail function add this:
dns.begin(dnsServerIP);
dns.getHostByName(serverName, remote_addr);
and change this
if (client.connect("api.pushingbox.com", 80)==true)
to this:
if (client.connect(remote_addr, 80)==true)
The DNSclient will try 3 times if it cant connect the first time, the number can be changed on line 160 of DNSclient.cpp
Also each loop has a 5sec timeout… the time out can be changed on line 276 of DNSclient.cpp
Hi Chris,
So your solution is not using the SparkCore internal DNS service and lookup IP with this code, correct ? Do you believe this is a problem with original release FW ?
I am using Cable for ISP and speed is 15Mbps which should not be slow problem.
I also tried with both PuTTY and CURL today again, both working just fine. So I doubt this is my Router DNS issue (I hope not).
It was just a fix for the issue i had on really slow internet offshore, but then I had a few times at home where i didn’t get emails, so i added it to that core and i haven’t missed an email that i know of yet.
and yep I’m bypassing the built in one in favor of the one i ported from arduino
I should have done a bit more work testing where the core firmware failed and error numbers and see what we could do to change it, but its all well over my head and it was in c not cpp and i got so lost…
I dig through the previous discussion below and I got the same result by calling gethostbyname(); Is "-85" return status meant timeout or something else ?
0.0.0.0
-85
901
This make me wonder that I am having a different problem that u originally trying to resolve.
Connecting with TCPclient code, and PING issues - Troubleshooting - Particle
So the WifI class brings out a bunch of useful information from the TI CC3000 configuration, but that does not include the DNS server by default. But you can access it yourself and check that it makes sense for your router–normally the DNS host is the same as the gateway host and is your router.
Here’s how:
   IPAddress dnshost(ip_config.aucDNSServer[3], ip_config.aucDNSServer[2], ip_config.aucDNSServer[1], ip_config.aucDNSServer[0]);
    Serial.print(dnshost);
I sent some time on the TI side to try to find out what error the -85 return code means but I didn’t find it. These come from inside the TI CC3000 and not from core firmware (except for -1 when the host name is too long).
-85 is indeed a strange one… maybe we are stuffing something maybe a int32_t into the int16_t that we set for the return value
901 is the same timeout i got… that seems to be the built in timeout
