Trouble understanding how to use Char * variable
Hi All,
I have code that will compile and run, but has a bunch of warnings about some variables I use.
I declare a variable before setup, and then during the setup routine, I use the particle ID to get site specific details. I'll use one here which is an API key - the API key gets the particular site data to the right graph so we understand where it came from.
I declare a variable:
char * myWriteAPIKey;
Then I put the data into the variable:
if (myID.equals("e00fce68370b9dd38b709203")) {
myWriteAPIKey = "APIKEYGOESHERE";
but I get the following problem during compile:
warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
how do I get the char* or string formatted properly?
That will happen, and there are two common fixes:
const char *
You can change the global variable declaration to:
const char * myWriteAPIKey;
The reason for this is that with a const char * you can change the pointer, but you can't change the contents of the things that are pointed to. So you can assign it to a different string, but you couldn't change only the first character of the string, for example.
This is important because the string in myWriteAPIKey = "APIKEYGOESHERE"is a const string. The string is stored in flash memory with the code and can't be modified at runtime, so you can't assign it to a char * variable because that means the string to be modified, and it can't be modified.
String
The other common solution is to declare it like this:
String myWriteAPIKey;
The main difference is that when you do the assignment, you are making a copy of the string. So the const string "APIKEYGOESHERE" still exists in flash memory in the code, but when you assign it, a copy is made to myWriteAPIKey on the heap. That allows it to be modified later, if desired.
