Hi all
I'm trying to parse some weather data from OpenWeatherMap.com. I'm getting the JSON into the terminal, but I can't parse it. Here is the JSON:
{"coord":{"lon":-87.65,"lat":41.85},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04d"}],"base":"stations","main":{"temp":302.06,"pressure":1017,"humidity":51,"temp_min":300.15,"temp_max":305.15},"visibility":16093,"wind":{"speed":5.1,"deg":260},"clouds":{"all":90},"dt":1505675700,"sys":{"type":1,"id":966,"message":0.0037,"country":"US","sunrise":1505648038,"sunset":1505692478},"id":4887398,"name":"Chicago","cod":200}
I have a feeling I'm messing up where I'm doing Serial.printlnf("TempF: ", root["coord"]["lon"].asString()); ,that's not working. To start, I was just trying to parse the longitude, so then I could, ideally, be able to parse anything like the temp, wind, etc. Any ideas?
Here is my code:
#include <SparkJson.h>
int i = 0;
void myHandler(const char *event, const char *data)
i++;
Serial.print(i);
Serial.print(event);
Serial.print(", data: ");
if (data)
Serial.println(data);
else
Serial.println("NULL");
const char *rawJsonData = data;
char *dataCopy = strdup(rawJsonData);
parseWeather(dataCopy);
void parseWeather(char *data); // forward declaration
Particle.subscribe("hook-response/temperature", myHandler, MY_DEVICES);
void loop(){
delay(1000);
void parseWeather(char *mutableData) {
StaticJsonBuffer<1000> jsonBuffer;
JsonObject& root = jsonBuffer.parseObject(mutableData);
if (!root.success()) {
Serial.println("parseObject() failed");
return;
