SYSTEM_MODE(MANUAL);
#include "Serial4/Serial4.h"
#include "Serial5/Serial5.h"
/// variables //////////////////////
boolean lock5 = false;
boolean lock4 = false;
boolean lock1 = false;
int ready = 0;
unsigned char rec_serial1[100],rec_serial5[100],rec_serial4[100];
char string1[200];
static int m=0,n5=0,n4=0;
char actualwt[7];
char actualwt1[7];
char actualcardidout[25];
char actualcardidin[25];
int terminal;
//Particle.subscribe("hook-response/weight", myHandler, MY_DEVICES);
pinMode( D7, OUTPUT);
pinMode( D4, OUTPUT);
pinMode( D0, OUTPUT);
pinMode( D2, OUTPUT);
Serial1.begin(2400); weigh machine
Serial4.begin(57600);//RFID card out 57600
Serial5.begin(57600);//RFID card in 57600
if(ready == 1)
send_in();
ready = 0;
else if(ready == 2)
send_out();
ready = 0;
else
//ready = 0;
void send_in()
digitalWrite(D7, HIGH);
memset(string1,0x00,sizeof(string1));
sprintf(string1,"{\"terminal\":\"%d\",\"cardid\":\"%s\",\"weight\":\"%s\"}",terminal,actualcardidin,actualwt1);
Serial.println(string1);
memset(actualcardidin,0x00,sizeof(actualcardidin));
memset(actualwt1,0x00,sizeof(actualwt1));
int lm=Serial4.available();
for(int im=0;im<=lm;im++)
Serial4.read();
lm = 0;
lm=Serial5.available();
Serial5.read();
lm=0;
lm=Serial1.available();
Serial1.read();
lock4 = false;
lock5 = false;
lock1 = false;
ready = 0;
digitalWrite(D7, LOW);
void send_out()
sprintf(string1,"{\"terminal\":\"%d\",\"cardid\":\"%s\",\"weight\":\"%s\"}",terminal,actualcardidout,actualwt1);
memset(actualcardidout,0x00,sizeof(actualcardidout));
Serial4.read();
lm = 0;
Serial5.read();
lm=0;
Serial1.read();
lock4 = false;
lock5 = false;
lock1 = false;
ready = 0;
void serialEvent1()
if(lock1 == true)
unsigned char a = Serial1.read();
if((strlen(actualcardidin)>=20) || (strlen(actualcardidout)>=20))
rec_serial1[m] = a;
m++;
Serial.println(rec_serial1[m]);
Serial.println("in if condition");
Serial.printlnf("m=%d",m);
if(m>=10)
m=0;
sprintf(actualwt,"%02X%02X%02X%02X%02X%02X",rec_serial1[2],rec_serial1[3],rec_serial1[4],rec_serial1[5],rec_serial1[6],rec_serial1[7]);
Serial.println(actualwt);
memset(rec_serial1,0x00,sizeof(rec_serial1));
if(strlen(actualcardidin)>=20)
Serial.println("in in uhf");
if(strlen(actualwt)>=6)
terminal = 1;
ready = 1;
strncpy(actualwt1, actualwt, 7);
memset(actualwt,0x00,sizeof(actualwt));
lock1 = false;
else{
Serial.println("no_weight");
if(strlen(actualcardidout)>=20)
terminal = 2;
ready = 2;
Serial.print("out");
lock1 = false;
else{
else
int l1=Serial1.available();
Serial.println(l1);
for(int im=0;im<=l1;im++)
Serial1.read();
void serialEvent4()
Serial.println("in uhf");
if(lock4==false)
unsigned char b = Serial4.read();
rec_serial4[n4]=b;
// n4=n4+1;
n4++;
if(n4>=10)
sprintf(actualcardidin,"%02X%02X%02X%02X%02X%02X%02X%02X%02X%02X",rec_serial4[0],rec_serial4[1],rec_serial4[2],rec_serial4[3],rec_serial4[4],rec_serial4[5],rec_serial4[6],rec_serial4[7],rec_serial4[8],rec_serial4[9]);
memset(rec_serial4,0x00,sizeof(rec_serial4));
Serial.println(actualcardidin);
n4=0;
lock4=true;
///blinkled2();
lock1=true;
else
int l4=Serial4.available();
Serial.println(l4);
for(int im=0;im<=l4;im++)
Serial4.read();
lock5=false; ////viraj
void serialEvent5()
Serial.println("out uhf");
if(lock5==false)
unsigned char c = Serial5.read();
rec_serial5[n5]=c;
n5++;
if(n5>=10)
sprintf(actualcardidout,"%02X%02X%02X%02X%02X%02X%02X%02X%02X%02X",rec_serial5[0],rec_serial5[1],rec_serial5[2],rec_serial5[3],rec_serial5[4],rec_serial5[5],rec_serial5[6],rec_serial5[7],rec_serial5[8],rec_serial5[9]);
memset(rec_serial5,0x00,sizeof(rec_serial5));
Serial.println(actualcardidout);
n5=0;
lock5=true;
/// blinkled4();
lock1=true;
else
int l5 = Serial5.available();
Serial.println(l5);
for(int im=0;im<=l5;im++)
Serial5.read();
lock4=false; ////viraj
the code in void loop() checks for if condition sends data to serial port of electron of serial 4 & 1 OR
serial 5 &1
the code reads any UHF data Serial event 4 or 5 at 57600 baud rate , then only seial event 1 at (2400 baud rate) read is considered
but serial event 1 gets always garbage value in variable actualwt sometimes its correct
anybody can help me please
