Trouble calling function from CLI
Hey all,
I am having trouble calling a function through cmd. I can get variables very easy however, when I call a function I always get this error- “Function call failed Timed Out”
I can do spark list and it shows the function there.
Im pretty sure my syntax is perfect, its also successfully verified from ide-
CMD -
spark call mycontroller changeMessage "NEWMESSAGE"
Spark IDE -
char msg[] = "DEFAULT";
void setup(){
     Spark.variable("mymessage", msg, STRING);
     Spark.function("changeMessage",changeMessage);
void loop(){}
int changeMessage(String newMessage){
     strcpy(msg, newMessage.c_str());
    return 1;
What should I look into on how to fix this problem?
Hi @flashyourface,
In future, please paste your code with the following syntax:
 ```cpp
 paste code here
Try commenting out ```  strcpy(msg, newMessage.c_str());``` and see what happens
I actually just found the solution, it was very dumb (probably because im so new to c).
This line -
had to be changed to this -
Spark.function("change",changeMessage);
It did not like having the same id name as the function name which is kind of silly.
Thanks @kennethlimcp for the tip on how to post code, ill do that from now on.
Was that the fix? That’s weird caused i used to do that with the same function name exposed with the corresponding function given the same name.
That was exactly the fix. I got the idea from someone who had the same exact problem in this post:
Though your rite in expecting it work, I would and have done the same in other languages. Maybe its this specific case?
@flashyourface, the function key should be less than 12 characters.
http://docs.spark.io/firmware/#spark-function
Just a heads up that this code could potentially corrupt memory. It only reserves 8 characters (7 chars plus the null character) for the array pointed to by msg in the line
The function changeMessage copies the contents of newMessage into the array even if changeMessage contains more than 8 characters. This will lead to memory issues.
Refer to this excellent post (another post latter in the thread, by Zachary, gives a great intro to C strings):
@flashyourface I know you've already seen this, but I thought it would improve this thread to reference it.
AH @krvarma Thanks that makes so much sense!
Thanks @brett13 I actually learned the hard way and got the red light flashing for that exact problem then I updated to have char msg[100] and that kept me a bit safer!
