Tracker SoM panic 13 stack overflow in Device OS: PC hits FirmwareUpdate::process()
Hello all,
I’m debugging repeated panic code 13 (stack overflow) on a Tracker SoM (T524), Device OS 6.3.3. I added custom PANIC_INFO publishing and every crash reports the same addresses:
{"code":13,"pc":"0x0004b05c","lr":"0x0004e43b","extra":"0x00000000"}
Code to publish/gather this information:
PanicData pdata = {};
    pdata.size = sizeof(pdata);
    if (panic_get_last_panic_data(&pdata, nullptr) == 0)
        g_pendingPanicCode = pdata.code;
        g_pendingPanicPc = (uint32_t)pdata.pc;
        g_pendingPanicLr = (uint32_t)pdata.lr;
        g_pendingPanicExtra = (uint32_t)pdata.extra_code;
        g_pendingPanicInfo = true;
#ifdef CONNECT_TO_CLOUD
    g_pendingPanicCode = panicCode; // This gets published later on to cloud
#endif
Using system-part1 symbols built from Device OS 6.3.3, PC resolves to:
particle::protocol::FirmwareUpdate::process() in communication/src/firmware_update.cpp:173
LR resolves to prohibit_xip in hal/src/nRF52840/core_hal.c:333.
These addresses are inside system-part1 flash (0x00028000–0x000b4000), not user firmware. Updates are expected in the project (OTA).
Has anyone seen stack overflows inside FirmwareUpdate::process()? Any suggestions for additional instrumentation or known issues around OTA in 6.3.3?
Thanks in advance,
Matej
Any support I can get on this please?
Thank you
Hi @PkStrSk,
SOS 13 can be a FreeRTOS stack overflow detection from the currently running task. When the task’s stack is exhausted, the next call frame (often a path like OTA processing) can be where things blow up. The PC/LR you see can be where the overflow was noticed, not necessarily where stack usage started growing.
Two things to try:
  1. Update to the latest Device OS release (6.3.5)
  2. Try to strip down your user space firmware to see if the overflow stops occurring at some lower complexity.
