Tracker Edge version 16 released
Tracker Edge version 16 has been released with some updates for the GNSS module. Take a look at Release Tracker Edge Firmware v16 · particle-iot/tracker-edge · GitHub for more information.
Built on device OS v3.1.0.
In summary:
FEATURES
  • Additional setting and implementation for GNSS initialization retries if failures are detected.
ENHANCEMENTS
  • The ublox GPS library has been updated to provide performance counters.
BUGFIXES
  • Fix to calculating sleep and execution times when the device is in areas of low connectivity.
OTHER CHANGES
  • Switched several logging calls from the LOG() macro to the functional Log() method.
Woohoo!
