Too few arguments to function. How to get enough?
Hey there awsome community!
I got a problem with this function. I got it from at project im used to run in Arduino environment without any errors, but when i try to upload to the Spark Core i get an error saying “too few arguments to function”. I have an idea why it says it, but i don’t know how to solve it.
I would appreciate any suggestions on how to solve this, though it might be simple solve, i just don’t know how.
Thanks!!
Code:
int T[] = {0x15, 0x38, 0x32, 0x2c, 0x0d, 0x13, 0x07, 0x2a};
int b(int i, int j, int k, int B) {
    return T[b(i, B) << 2 | b(j, B) << 1 | b(k, B)];
Error:
…/src/application.cpp
…/src/application.cpp: In function ‘int b(int, int, int, int)’:
…/src/application.cpp:331:20: error: too few arguments to function ‘int b(int, int, int, int)’
…/src/application.cpp:330:5: note: declared here
…/src/application.cpp:331:35: error: too few arguments to function ‘int b(int, int, int, int)’
…/src/application.cpp:331:50: error: too few arguments to function ‘int b(int, int, int, int)’
…/src/application.cpp:332:1: warning: control reaches end of non-void function [-Wreturn-type]
make: *** [obj/src/application.o] Fejl 1
BUILD FAILED (exit value 2, total time: 989ms)
Hi @simoher
OK, you have an array T with some int’s in it. Then you have a function b that takes four arguments, i, j, k, and B and calls itself recursively to build an index into the array T. But the recursive calls only pass two arguments to function b, not the four it requires and function b is missing its final closing curly brace.
Did you rename something or edit something from the working version?
This is not going to compile without fixes in any compiler, but I can’t quite see what you are trying to do to help more.
On other thing that can trip you up coming from Arduino that on Arduino, int is a 16-bit type but on Spark int is a 32-bit type.
Hmmm, still no idea how to fix this. I’m trying to run some simplex noise on my LED-stip (very nice effect).
Here are the code that are complying on arduino:
Fast and smooth random colour patterns for a LPD8066 addressable RGB LED strip.
By happyinmotion (jez.weston@yahoo.com)
Simplex noise code taken from Stephen Carmody's Java implementation at:
http://stephencarmody.wikispaces.com/Simplex+Noise
Perlin Noise code copyright 2007 Mike Edwards:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1191768812
// Timing results on a 96 LED strip controlled by an Arduino Nano v3:
// Perlin noise - 10 ms per LED per colour
// Simplex noise - 1 ms per LED per colour
// Cubic interpolation - 0.02 ms per LED per colour
// Smooth motion needs a refresh every 50 ms or so. For a 96 RGB LED strip, I used 6 simplex nodes with interpolation between to get it all smoothly flowing.
// LPD8806-based code from Adafruit for RGB LED Modules in a strip
// you can also use hardware SPI, for ultra fast writes by leaving out the
// data and clock pin arguments. This will 'fix' the pins to the following:
// on Arduino 168/328 thats data = 11, and clock = pin 13.
#include "LPD8806.h"
#include "SPI.h"
int dataPin  = 2;
int clockPin = 3;
// Strip variables:
const int LEDs_in_strip = 90;
const int LEDs_for_simplex =3;
// Extra fake LED at the end, to avoid fencepost problem.
// It is used by simplex node and interpolation code.
float LED_array_red[LEDs_in_strip+1];
float LED_array_green[LEDs_in_strip+1];
float LED_array_blue[LEDs_in_strip+1];
float LED_array_hue[LEDs_in_strip+1];
float LED_array_brightness[LEDs_in_strip+1];
int node_spacing = LEDs_in_strip / LEDs_for_simplex;
LPD8806 strip = LPD8806(LEDs_in_strip, dataPin, clockPin);
// Perlin noise global variables:
float x1,y1,x2,y2;
// Set up Perlin globals:
//persistence affects the degree to which the "finer" noise is seen
float persistence = 0.25;
//octaves are the number of "layers" of noise that get computed
int octaves = 3;
// Simplex noise global variables:
int i, j, k, A[] = {0, 0, 0};
float u, v, w, s;
static float onethird = 0.333333333;
static float onesixth = 0.166666667;
// Simplex noise parameters:
// Useable values for time increment range from 0.005 (barely perceptible) to 0.2 (irritatingly flickery)
// 0.02 seems ideal for relaxed screensaver
float timeinc = 0.008;
// Useable values for space increment range from 0.8 (LEDS doing different things to their neighbours), to 0.02 (roughly one feature present in 15 LEDs).
// 0.05 seems ideal for relaxed screensaver
float spaceinc = 0.9;
// Simplex noise variables:
// So that subsequent calls to SimplexNoisePattern produce similar outputs, this needs to be outside the scope of loop()
float yoffset = 0.0;
float saturation = 1.0;
  // Start up the LED strip
  strip.begin();
  // Update the strip, to start they are all 'off'
  strip.show();
  Serial.println("Setup done ");
  int repeats = 200;
// Perlin noise for five red LEDs
  timeinc = 0.1;
  for ( int i=0; i<repeats; i++ ) {
    PerlinNoisePattern( 5 );
    yoffset += timeinc;
  AllOff();
  delay(500);
  // Simplex noise for ten full-colour LEDs
  // No interpolation.
  timeinc = 0.02;
    SimplexNoisePattern( spaceinc, timeinc, yoffset, 10);
    yoffset += timeinc;
  AllOff();
  delay(500);
int mode = 0;
switch(mode) {
  case 0: //solid
  // Simplex noise for whole strip of 96 LEDs.
  // (Well, it's simplex noise for 6 LEDs and cubic interpolation between those nodes.)
    SimplexNoisePatternInterpolated( spaceinc, timeinc, yoffset);
    yoffset += timeinc;
    break;
      case 1: // fast flash
 break;
 // AllOff();
  //delay(500);
void PerlinNoisePattern(int numLEDs) {
  float xoffset = 1.0;
  for (int j=0; j < numLEDs; j++) {
    xoffset += spaceinc;
    // Caluclate Perlin Noise (range -1 to 1), expand and bias that range:
    // Takes around 10 ms per call, so only doing this for the red LEDs, not full colour
    int r = int(PerlinNoise2(xoffset,yoffset,persistence,octaves)*196+32);
    // Clip output to the brightness level of 0-127 that the LED strip accepts.
    // Doing this with constrain() is slooow. Doing this explicitly adds no time at all. Conclusion: constrain() sucks.
    if ( r>127 ) { r=127; }
    else if ( r<0 ) { r=0; }
    strip.setPixelColor(j, r, 0, 0);
  strip.show();
void SimplexNoisePattern( float spaceinc, float timeinc, float yoffset, int numLEDs) {
    // Calculate simplex noise for LEDs that are nodes:
    // Store raw values from simplex function (-0.347 to 0.347)
    float xoffset = 0.0;
    for (int i=0; i<numLEDs; i++) {
      LED_array_red[i] = SimplexNoise(xoffset,yoffset,0);
      LED_array_green[i] = SimplexNoise(xoffset,yoffset,1);
      LED_array_blue[i] = SimplexNoise(xoffset,yoffset,2);
    // Convert values from raw noise to scaled r,g,b and feed to strip.
    // Raw noise is -0.347 to +0.347 or thereabouts.
      int r = int(LED_array_red[i]*403 + 16);
      int g = int(LED_array_green[i]*403 + 16);
      int b = int(LED_array_blue[i]*403 + 16);
      else if ( r<0 ) { r=0; }  // Adds no time at all. Conclusion: constrain() sucks.
      if ( g>127 ) { g=127; }
      else if ( g<0 ) { g=0; }
      if ( b>127 ) { b=127; }
      else if ( b<0 ) { b=0; }
      strip.setPixelColor(i, r, g, b);
    // Update strip
    strip.show();
void SimplexNoisePatternInterpolated( float spaceinc, float timeinc, float yoffset) {
    for (int i=0; i<=LEDs_in_strip; i=i+node_spacing) {
    // Interpolate values for LEDs between nodes
    for (int i=0; i<LEDs_in_strip; i++) {
      int position_between_nodes = i % node_spacing;
      int last_node, next_node;
      // If at node, skip
      if ( position_between_nodes == 0 ) {
        // At node for simplex noise, do nothing but update which nodes we are between
        last_node = i;
        next_node = last_node + node_spacing;
      // Else between two nodes, so identify those nodes
      else {
        // And interpolate between the values at those nodes for red, green, and blue
        float t = float(position_between_nodes) / float(node_spacing);
        float t_squaredx3 = 3*t*t;
        float t_cubedx2 = 2*t*t*t;
        LED_array_red[i] = LED_array_red[last_node] * ( t_cubedx2 - t_squaredx3 + 1.0 ) + LED_array_red[next_node] * ( -t_cubedx2 + t_squaredx3 );
        LED_array_green[i] = LED_array_green[last_node] * ( t_cubedx2 - t_squaredx3 + 1.0 ) + LED_array_green[next_node] * ( -t_cubedx2 + t_squaredx3 );
        LED_array_blue[i] = LED_array_blue[last_node] * ( t_cubedx2 - t_squaredx3 + 1.0 ) + LED_array_blue[next_node] * ( -t_cubedx2 + t_squaredx3 );
    // Update strip
    strip.show();
// Simplex noise code:
// From an original algorythm by Ken Perlin.
// Returns a value in the range of about [-0.347 .. 0.347]
float SimplexNoise(float x, float y, float z) {
  // Skew input space to relative coordinate in simplex cell
  s = (x + y + z) * onethird;
  i = fastfloor(x+s);
  j = fastfloor(y+s);
  k = fastfloor(z+s);
  // Unskew cell origin back to (x, y , z) space
  s = (i + j + k) * onesixth;
  u = x - i + s;
  v = y - j + s;
  w = z - k + s;;
  A[0] = A[1] = A[2] = 0;
  // For 3D case, the simplex shape is a slightly irregular tetrahedron.
  // Determine which simplex we're in
  int hi = u >= w ? u >= v ? 0 : 1 : v >= w ? 1 : 2;
  int lo = u < w ? u < v ? 0 : 1 : v < w ? 1 : 2;
  return k_fn(hi) + k_fn(3 - hi - lo) + k_fn(lo) + k_fn(0);
int fastfloor(float n) {
  return n > 0 ? (int) n : (int) n - 1;
float k_fn(int a) {
  s = (A[0] + A[1] + A[2]) * onesixth;
  float x = u - A[0] + s;
  float y = v - A[1] + s;
  float z = w - A[2] + s;
  float t = 0.6f - x * x - y * y - z * z;
  int h = shuffle(i + A[0], j + A[1], k + A[2]);
  A[a]++;
  if (t < 0) return 0;
  int b5 = h >> 5 & 1;
  int b4 = h >> 4 & 1;
  int b3 = h >> 3 & 1;
  int b2 = h >> 2 & 1;
  int b = h & 3;
  float p = b == 1 ? x : b == 2 ? y : z;
  float q = b == 1 ? y : b == 2 ? z : x;
  float r = b == 1 ? z : b == 2 ? x : y;
  p = b5 == b3 ? -p : p;
  q = b5 == b4 ? -q: q;
  r = b5 != (b4^b3) ? -r : r;
  t *= t;
  return 8 * t * t * (p + (b == 0 ? q + r : b2 == 0 ? q : r));
int shuffle(int i, int j, int k) {
  return b(i, j, k, 0) + b(j, k, i, 1) + b(k, i, j, 2) + b(i, j, k, 3) + b(j, k, i, 4) + b(k, i, j, 5) + b(i, j, k, 6) + b(j, k, i, 7);
int b(int N, int B) {
  return N >> B & 1;
// Perlin noise code:
// using the algorithm from http://freespace.banned.net/hugo.elias/models/m_perlin.html
// thanks to hugo elias
float Noise2(float x, float y)
  long noise;
  noise = x + y * 57;
  noise = (noise << 13) ^ noise;
  return ( 1.0 - ( long(noise * (noise * noise * 15731L + 789221L) + 1376312589L) & 0x7fffffff) / 1073741824.0);
float SmoothNoise2(float x, float y)
  float corners, sides, center;
  corners = ( Noise2(x-1, y-1)+Noise2(x+1, y-1)+Noise2(x-1, y+1)+Noise2(x+1, y+1) ) / 16;
  sides   = ( Noise2(x-1, y)  +Noise2(x+1, y)  +Noise2(x, y-1)  +Noise2(x, y+1) ) /  8;
  center  =  Noise2(x, y) / 4;
  return (corners + sides + center);
float InterpolatedNoise2(float x, float y)
  float v1,v2,v3,v4,i1,i2,fractionX,fractionY;
  long longX,longY;
  longX = long(x);
  fractionX = x - longX;
  longY = long(y);
  fractionY = y - longY;
  v1 = SmoothNoise2(longX, longY);
  v2 = SmoothNoise2(longX + 1, longY);
  v3 = SmoothNoise2(longX, longY + 1);
  v4 = SmoothNoise2(longX + 1, longY + 1);
  i1 = Interpolate(v1 , v2 , fractionX);
  i2 = Interpolate(v3 , v4 , fractionX);
  return(Interpolate(i1 , i2 , fractionY));
float Interpolate(float a, float b, float x)
  //cosine interpolations
  return(CosineInterpolate(a, b, x));
float LinearInterpolate(float a, float b, float x)
  return(a*(1-x) + b*x);
float CosineInterpolate(float a, float b, float x)
  float ft = x * 3.1415927;
  float f = (1 - cos(ft)) * .5;
  return(a*(1-f) + b*f);
float PerlinNoise2(float x, float y, float persistance, int octaves)
  float frequency, amplitude;
  float total = 0.0;
  for (int i = 0; i <= octaves - 1; i++)
    frequency = pow(2,i);
    amplitude = pow(persistence,i);
    total = total + InterpolatedNoise2(x * frequency, y * frequency) * amplitude;
  return(total);
void AllOff() {
  // Reset LED strip
  strip.begin();
  strip.show();
And the code i’m trying to get running on Spark Core:
 * @file    application.cpp
 * @authors  Satish Nair, Zachary Crockett and Mohit Bhoite
 * @version V1.0.0
 * @date    05-November-2013
 * @brief   Tinker application
  Copyright (c) 2013 Spark Labs, Inc.  All rights reserved.
  This program is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation, either
  version 3 of the License, or (at your option) any later version.
  This program is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this program; if not, see <http://www.gnu.org/licenses/>.
/* Includes ------------------------------------------------------------------*/
#include "application.h"
#include "spark_disable_wlan.h"
#include "spark_disable_cloud.h"
#include "math.h"
// Simple test for 160 (5 meters) of LPD8806-based RGB LED strip
// Number of RGB LEDs in strand:
int nLEDs = 50;
// Chose 2 pins for output; can be any valid output pins:
int dataPin = D0;
int clockPin = D1;
// You can optionally use hardware SPI for faster writes, just leave out
// the data and clock pin parameters.  But this does limit use to very
// specific pins on the Arduino.  For "classic" Arduinos (Uno, Duemilanove,
// etc.), data = pin 11, clock = pin 13.  For Arduino Mega, data = pin 51,
// clock = pin 52.  For 32u4 Breakout Board+ and Teensy, data = pin B2,
// clock = pin B1.  For Leonardo, this can ONLY be done on the ICSP pins.
//LPD8806 strip = LPD8806(nLEDs)
// Strip variables:
const int LEDs_in_strip = 50;
const int LEDs_for_simplex = 3;
float LED_array_red[LEDs_in_strip + 1];
float LED_array_green[LEDs_in_strip + 1];
float LED_array_blue[LEDs_in_strip + 1];
float LED_array_hue[LEDs_in_strip + 1];
float LED_array_brightness[LEDs_in_strip + 1];
float CosineInterpolate(float a, float b, float x);
float Interpolate(float a, float b, float x);
int octaves = 3;
float u, v, w, s;
void SimplexNoisePatternInterpolated(float spaceinc, float timeinc, float yoffset);
float SimplexNoise(float x, float y, float z);
int fastfloor(float n);
float k_fn(int a);
int shuffle(int i, int j, int k);
    WiFi.off();
    Spark.disconnect();
    pinMode(D7, OUTPUT);
    strip.begin();
    strip.show();
    int repeats = 200;
      timeinc = 0.1;
        yoffset += timeinc;
      AllOff();
      delay(500);
      timeinc = 0.02;
        yoffset += timeinc;
      AllOff();
      delay(500);
    int mode = 0;
    switch (mode) {
        case 0: //solid
            for (int i = 0; i < repeats; i++) {
                SimplexNoisePatternInterpolated(spaceinc, timeinc, yoffset);
                yoffset += timeinc;
            break;
            break;
    // AllOff();
    //delay(500);
void SimplexNoisePattern(float spaceinc, float timeinc, float yoffset, int numLEDs) {
    for (int i = 0; i < numLEDs; i++) {
        LED_array_red[i] = SimplexNoise(xoffset, yoffset, 0);
        LED_array_green[i] = SimplexNoise(xoffset, yoffset, 1);
        LED_array_blue[i] = SimplexNoise(xoffset, yoffset, 2);
        if (r > 127) {
            r = 127;
        } else if (r < 0) {
            r = 0;
        if (g > 127) {
            g = 127;
        } else if (g < 0) {
            g = 0;
        if (b > 127) {
            b = 127;
        } else if (b < 0) {
            b = 0;
    // Update strip
    strip.show();
void SimplexNoisePatternInterpolated(float spaceinc, float timeinc, float yoffset) {
    for (int i = 0; i <= LEDs_in_strip; i = i + node_spacing) {
    for (int i = 0; i < LEDs_in_strip; i++) {
        // If at node, skip
        if (position_between_nodes == 0) {
            last_node = i;
        }            // Else between two nodes, so identify those nodes
        else {
            float t_squaredx3 = 3 * t*t;
            float t_cubedx2 = 2 * t * t*t;
            LED_array_red[i] = LED_array_red[last_node] * (t_cubedx2 - t_squaredx3 + 1.0) + LED_array_red[next_node] * (-t_cubedx2 + t_squaredx3);
            LED_array_green[i] = LED_array_green[last_node] * (t_cubedx2 - t_squaredx3 + 1.0) + LED_array_green[next_node] * (-t_cubedx2 + t_squaredx3);
            LED_array_blue[i] = LED_array_blue[last_node] * (t_cubedx2 - t_squaredx3 + 1.0) + LED_array_blue[next_node] * (-t_cubedx2 + t_squaredx3);
        if (r > 127) {
            r = 127;
        } else if (r < 0) {
            r = 0;
        if (g > 127) {
            g = 127;
        } else if (g < 0) {
            g = 0;
        if (b > 127) {
            b = 127;
        } else if (b < 0) {
            b = 0;
    // Update strip
    strip.show();
    i = fastfloor(x + s);
    j = fastfloor(y + s);
    k = fastfloor(z + s);
    u = x - i + s;
    v = y - j + s;
    w = z - k + s;
float k_fn(int a) {
    A[a]++;
    int b = h & 3;
    q = b5 == b4 ? -q : q;
    t *= t;
    return N >> B & 1;
float Noise2(float x, float y) {
    long noise;
    noise = x + y * 57;
    return ( 1.0 - (long(noise * (noise * noise * 15731L + 789221L) + 1376312589L) & 0x7fffffff) / 1073741824.0);
float SmoothNoise2(float x, float y) {
    corners = (Noise2(x - 1, y - 1) + Noise2(x + 1, y - 1) + Noise2(x - 1, y + 1) + Noise2(x + 1, y + 1)) / 16;
    sides = (Noise2(x - 1, y) + Noise2(x + 1, y) + Noise2(x, y - 1) + Noise2(x, y + 1)) / 8;
float InterpolatedNoise2(float x, float y) {
    float v1, v2, v3, v4, i1, i2, fractionX, fractionY;
    long longX, longY;
    longX = long(x);
    longY = long(y);
    i1 = Interpolate(v1, v2, fractionX);
    i2 = Interpolate(v3, v4, fractionX);
    return (Interpolate(i1, i2, fractionY));
float Interpolate(float a, float b, float x) {
    return (CosineInterpolate(a, b, x));
float LinearInterpolate(float a, float b, float x) {
    return (a * (1 - x) + b * x);
float CosineInterpolate(float a, float b, float x) {
    return (a * (1 - f) + b * f);
float PerlinNoise2(float x, float y, float persistance, int octaves) {
    float total = 0.0;
    for (int i = 0; i <= octaves - 1; i++) {
        frequency = pow(2, i);
        amplitude = pow(persistence, i);
    return (total);
void AllOff() {
    // Reset LED strip
    strip.begin();
    strip.show();
There are two functions named "b"--you need to rename one of them like this:
  return T[b2(i, B) << 2 | b2(j, B) << 1 | b2(k, B)];
int b2(int N, int B) {
  return N >> B & 1;
You should check the other callers of b() if any and change them as needed: four arguments for "b" and two arguments for "b2". This is not legal C or C++ so I am not sure how it works in Arduino land--the pre-processor must be doing something.
I see no no callers for either of the “b” functions.
Don’t you think that the second “b” just modify the first one?
Hmm, i was planing to use this effect at a party tonight, but i might just forget that…
The function b with four arguments is called by shuffle() which is called above k_fn().
