jrjack
April 21, 2019, 5:03pm
1
I have the following code where i am getting the data in the following from: “3,0,null,Simple”
I want to tokenize this, and break the string and return it back into an array so that
s[0] = “3”
s[1] = “0”
s[2] = “null”
s[3] = “Simple”
I wrote the following code and was wondering if this was correct, and if there was a better way to do this?
String* TokenizeString(String Input){
int firstCommaIndex = Input.indexOf(',');
int secondCommaIndex = Input.indexOf(',', firstCommaIndex+1);
int thirdCommaIndex = Input.index(',', secondCommaIndex+1);
String sNumber = Input.substring(0, firstCommaIndex);
String sTimer = Input.substring(firstCommaIndex+1, secondCommaIndex);
String sType = Input.substring(secondCommaIndex+1);
String sIntent = Input.substring(thirdCommaIndex+1);
String sReturnString[4] = {sNumber, sTimer, sType, sIntent};
return sReturnString;
I would stay away from String but use vanilla C strings.
And with that you could use strtok() or something like this
struct myData {
int number;
int timer;
char s[2][16];
// Input:
// stringToParse like "3,0,null,Simple"
// *outData address of parsed data
// Returns:
// number of successfully parsed fields in outData
int TokenizeString(const char* stringToParse, myData *outData) {
return sscanf(stringToParse
, "%d,%d,%15s,%15s"
, &outData->number
, &outData->timer
, outData->s[0]
, outData->s[1]);
(see sscanf() )
I agree with ScruffR, strtok is a better option in my opinion as well.
However if you stick with String, this won’t work:
You can return a String object from a function, because the String object will be copied, even if the source is a stack allocated variable.
You cannot return an array of anything (including String), because the C compiler can’t copy an array by value. That code is not a good idea because the array will be allocated on the stack and disappears when the function exits, before it can be used. It might happen to work sometimes, but it’s a really bad idea.
