Tiny WebServer code
Hi @darek_student
I am glad it worked out for you! It occurred to me after I posted that one of my tutorial web pages would well for you:
If you use edit the HTML file in this example to add your access token (which you need to keep secret) and the load this page in a web browser using the file:/// syntax, you can enter your publish string (“myIPAddr”) and see you address easily:
