@bko Thank you alot, that worked and to me it seems much simpler than to be connected serial and instaling programs and so on, but that’s my opinion
I am glad it worked out for you! It occurred to me after I posted that one of my tutorial web pages would well for you:
If you use edit the HTML file in this example to add your access token (which you need to keep secret) and the load this page in a web browser using the file:/// syntax, you can enter your publish string (“myIPAddr”) and see you address easily:
hi @bko i followed the steps but the website doesn’t shows
webClient.println(“I’m serving a webpage!\n\n”);
this line of code. mind helping me out? thanks
Hi @JAlonso
Sorry I was away for a few days.
Are you sure you have the right local address? How are you getting that? Via publish or checking router logs or static IP?
What happens when you do go to the address? Anything at all?
What happens if you use curl like this:
curl -v http://10.0.1.5
substituting your core’s IP address for 10.0.1.5 or course.
Hi @bko thx for reply, its ok for late or what haha
yes i see an publish ip address via “view-source:https://api.spark.io/v1/devices/device_id/events/myIPAddr/?access_token=<>” when i go to the address, which i published, it give me nothing.
where shoud i put “curl -v http://10.0.1.5” ? in cmd? in code? after substituting core IP to 10.0.1.5, then 10.0.1.5 will be the address to access core?
Hi @JAlonso
Whatever IP address you get back from the
URL in your browser (let’s pretend you got back 192.168.0.3 for example), then in a cmd shell (assuming you have installed curl) do this:
curl -v http://192.168.0.3
so, after i installed curl(currently don’t know what is this), i go to cmd and run “curl -v http://ip_i_get” then i can access the core with “ip_i_get”?
Hi @JAlonso
curl does web requests (GET PUT POST) like a browser but from the command line. The -v flag is verbose and will tell us if the connection is responding at all. It is just a debugging tool.
thx appreciated that… will try out with core tomorrow. thx again.
Ok. It’s 2017 now, and here are some changes and hints to get this example to work.
- Compiler tells me Spark is deprecated in favor of Particle. Ok. Small change. and it’s only a deprecation, not an error.
- Problem. "/workspace/tinywebserver.cpp:11: undefined reference to
spark::NetworkClass::localIP()
" On expanding error the helpful line is replaceNetwork.localIP();
withWiFi.localIP();
- Go to https://console.particle.io/devices , find your device, Under
Variables
->ipAddress
, click [Get
] and read the IP address. It might be something like192.168.0.104
. - Open a browser and type in that ip with aport of
80
. For example192.168.0.104:80
. You should get a web page that saysI'm serving a webpage!
