I saw there was a bit of trouble a while back (~ a year ago?) with printf and floats. Seems like this was fixed. using printfs in loop() or setup() with a float, no problem.
But when I try todo this with a timer, I get an SOS with a single flash. Am I doing something wrong? or did I step on a bug? It seems the workaround for typecasting to a string does resolve the problem, but curious if this is a different printf/float issue? Running this on last RC code and 0.5.3 firmware yield same SOS.
void print_every_second()
char msg[255];
float floatVar = 0.01; // our readings
sprintf(msg, "%0.2f", floatVar);
Timer timer(1000, print_every_second);
timer.start();
Serial.println("setup() - complete");
