I’m trying to connect a K30 CO2 sensor to a Photon and get the data into Thingspeak. I’ve already got one unit working through I2C but this is a bit unstable. So I was trying to connect the sensor to the Photon through the serial port: Serial1. The strange thing is that as soon as I include and activate Thingspeak in the code it breaks the program (I get SOS flashing). Vice versa same result (Thingspeak alone works, but SOS flashing as soon as I put Serial1.begin(9600) in the setup function).
Is there some timing thing in the Thingspeak library which breaks Serial1? Normal serial (‘Serial’) works.
Thanks for your reply. I don’t think the sensor uses interrupts, just simple communication.
Here’s the code. I modified it slightly from the original, written for the Arduino. But I did some tests with the Thingspeak examples, and as soon as you add Serial1.begin(9600) you get the SOS.
The SOS-code is 1 blink, after the SOS, so a Hard Fault.
#include "ThingSpeak/ThingSpeak.h"
Basic rduino example for K-Series sensor
Created by Jason Berger
Co2meter.com
Modified for the Particle Photon by Corneel Canters
TCPClient client;
unsigned long myChannelNumber = ******;
const char * myWriteAPIKey = "xxxxxxxxxxxxxx";
byte readCO2[] = {0xFE, 0X44, 0X00, 0X08, 0X02, 0X9F, 0X25}; //Command packet to read Co2 (see app note)
byte response[] = {0, 0, 0, 0, 0, 0, 0}; //create an array to store the response
//multiplier for value. default is 1. set to 3 for K-30 3% and 10 for K-33 ICB
int valMultiplier = 1;
long co2Value = 0; //
int ts_loop = 0; // variable for counting number of loops so value only sent once every 20 seconds to Thingspeak
Particle.variable("ppm2", co2Value); // container for viewing value directly
Serial1.begin(9600); //Opens the serial port to communicate with the co2 sensor
ThingSpeak.begin(client);
sendRequest(readCO2);
unsigned long valCO2 = getValue(response);
co2Value = int(valCO2);
delay(2000); // 2 second delay. CO2 sensor takes new reading every 2 seconds
if (ts_loop == 0) {
ThingSpeak.writeField(myChannelNumber, 1, 400, myWriteAPIKey); // writ evalue to Thingspeak
if (ts_loop >= 10) // after 20 seconds reset
ts_loop = 0;
else
ts_loop++;
void sendRequest(byte packet[])
while (!Serial1.available()) //keep sending request until we start to get a response
Serial1.write(readCO2, 7);
delay(50);
int timeout = 0; //set a timeoute counter
while (Serial1.available() < 7 ) //Wait to get a 7 byte response
timeout++;
if (timeout > 10) //if it takes to long there was probably an error
while (Serial1.available()) //flush whatever we have
Serial1.read();
break; //exit and try again
delay(50);
for (int i = 0; i < 7; i++)
response[i] = Serial1.read();
unsigned long getValue(byte packet[])
int high = packet[3]; //high byte for value is 4th byte in packet in the packet
int low = packet[4]; //low byte for value is 5th byte in the packet
unsigned long val = high * 256 + low; //Combine high byte and low byte with this formula to get value
return val * valMultiplier;
