Thank you very much for your reply @rickkas7
I have made some progress and it works but not always
I have used Curl to send the GET request to my server and monitored the traffic with Wireshark. So I found out how the request needs to be formatted:
Curl request:
curl -GET “http://mydyndnsaddress:8086/query” --data-urlencode “db=sensors” --data-urlencode “q=SELECT LAST(kWh) FROM sensors WHERE Location=‘street’”
curl -GET “http://mydyndnsaddress:8086/query” --data-urlencode “db=mydb” --data-urlencode “q=SELECT LAST(value) FROM cpu_load_short WHERE region=‘us-west’”
Wireshark:
Frame 15: 227 bytes on wire (1816 bits), 227 bytes captured (1816 bits) on interface 0
Ethernet II, Src: IntelCor_ae:db:c8 (00:24:d7:ae:db:c8), Dst: Elitegro_77:e4:7a (b8:ae:ed:77:e4:7a)
Internet Protocol Version 4, Src: 10.0.0.17, Dst: 10.0.0.14
Transmission Control Protocol, Src Port: 1532 (1532), Dst Port: 8086 (8086), Seq: 1, Ack: 1, Len: 173
Hypertext Transfer Protocol
GET /query?db=sensors&q=SELECT%20LAST%28kWh%29%20FROM%20sensors%20WHERE%20Location%3D%27street%27 HTTP/1.1\r\n
[Expert Info (Chat/Sequence): GET /query?db=sensors&q=SELECT%20LAST%28kWh%29%20FROM%20sensors%20WHERE%20Location%3D%27street%27 HTTP/1.1\r\n]
Request Method: GET
Request URI: /query?db=sensors&q=SELECT%20LAST%28kWh%29%20FROM%20sensors%20WHERE%20Location%3D%27street%27
Request Version: HTTP/1.1
Host: 10.0.0.14:8086\r\n
User-Agent: curl/7.49.0\r\n
Accept: */*\r\n
\r\n
[Full request URI: http://10.0.0.14:8086/query?db=sensors&q=SELECT%20LAST%28kWh%29%20FROM%20sensors%20WHERE%20Location%3D%27street%27]
[HTTP request 1/1]
[Response in frame: 17]
Server response:
{"results":[{"series":[{"name":"sensors","columns":["time","last"],"values":[["1970-01-01T00:00:00Z",0.13]]}]}]}
I have also modified the code to read the incomming chars and wrote a complete new sketch just for reading the database. This sketch runs on a Particle Core:
#define INFLUXDB_HOST "my dyn dns address"
#define INFLUXDB_PORT 8086
#define INFLUXDB_DB "sensors"
#define DEBUG_SERIAL true
#define SKIP_CHARS 0
#define BUFFER_SIZE_MAX 1024
TCPClient client;
unsigned long previousMillis = 0;
unsigned long previousMillis2 = 0;
unsigned long interval = 15000;
char buffer[BUFFER_SIZE_MAX];
void readInflux()
int i = 0;
int j = 0;
int k = 0;
bool printOnce = false;
int i = 0;
int j = 0;
int k = 0;
if (client.connect(INFLUXDB_HOST, INFLUXDB_PORT)) {
client.print("GET ");
client.print("/query?db=sensors&q=SELECT%20LAST%28kWh%29%20FROM%20sensors%20WHERE%20Location%3D%27Bachgasse%27");
client.println(" HTTP/1.1");
client.print("HOST: ");
client.println(INFLUXDB_HOST);
client.println("Connection: close");
client.println();
client.flush();
} else {
if(DEBUG_SERIAL) Serial.println("\r\n\r\nConnection Failed!");
client.flush();
client.stop();
return;
// wait 5 seconds or less for the host to respond
uint32_t startTime = millis();
while(!client.available() && (millis() - startTime) < 5000);
if(DEBUG_SERIAL) Serial.println("\r\n\r\nREADING HOST DATA......");
uint32_t lastRead = millis();
// If the host doesn't close it's connection, we'll timeout in 10 seconds.
while (client.connected() && (millis() - lastRead) < 10000) {
while (client.available()) {
char c = client.read();
if(DEBUG_SERIAL) {
Serial.print(c);
if(i++ > 100) {
delay(5);
i = 0;
if(c == -1) {
Serial.print("\r\n\r\nERROR......\r\n\r\n");
client.flush();
client.stop();
if(j++ >= SKIP_CHARS) { // don't buffer the first X bytes to save memory
if(DEBUG_SERIAL && !printOnce) {
Serial.print("\r\n\r\nSAVING......\r\n\r\n");
printOnce = true;
buffer[k++] = c; // save character to buffer
Serial.print(c);
delayMicroseconds(100);
if(k >= BUFFER_SIZE_MAX) { // if we reach the end of our buffer, just bail.
Serial.print("\r\n\r\nOUT OF BUFFER SPACE......\r\n\r\n");
client.flush();
client.stop();
// as long as we're reading data, reset the lastRead time.
} // END while(client.available())
} // END while(client.connected())
client.flush();
client.stop();
if(DEBUG_SERIAL) {
Serial.print("\r\nCHARACTERS RECEIVED: ");
Serial.println(SKIP_CHARS + k);
Serial.begin(19200);
//kwh = readInflux();
void loop(){
unsigned long currentMillis = millis();
if(currentMillis - previousMillis >= interval) {
Serial.println("reading Influx");
readInflux();
previousMillis = currentMillis;
}else{
Serial.println("Device not ready");
delay(1000);
Serial output:
Device not ready
Device not ready
Device not ready
Device not ready
Device not ready
Device not ready
Device not ready
Device not ready
Device not ready
reading Influx
H
SAVING......
HTTTTPP//11..11 220000 OOKK
CCoonntteenntt--TTyyppee:: aapppplliiccaattiioonn//jjssoonn
RReeqquueesstt--IIdd:: bb55ccbb55557777--2255bbff--1111ee66--9933aa55--000000000000000000000000
XX--IInnfflluuxxddbb--VVeerrssiioonn:: 00..1122..11
DDaattee:: SSuunn,, 2299 MMaayy 22001166 1177::0066::4400 GGMMTT
CCoonntteenntt--LLeennggtthh:: 111122
CCoonnnneeccttiioonn:: cclloossee
{{""rreessuullttss""::[[{{""sseerriieess""::[[{{""nnaammee""::""sseennssoorrss"",,""ccoolluummnnss""::[[""ttiimmee"",,""llaasstt""]],,""vvaalluueess""::[[[[""11997700--0011--0011TT0000::0000::0000ZZ"",,00..1166]]]]}}]]}}]]}}
CHARACTERS RECEIVED: 318
Device not ready
Device not ready
Device not ready
Device not ready
Serial output when it is not working:
Device not ready
Device not ready
Device not ready
Device not ready
Device not ready
Device not ready
reading Influx
CHARACTERS RECEIVED: 0
Device not ready
Device not ready
Device not ready
Device not ready
Device not ready
The code I am using to read the characters is from @technobly: https://github.com/technobly/SparkCore-FacebookLikesAlert/blob/master/application.cpp
It seems to read the characters so fast that it is reading them multiple times. Is there a way to handle this?
Edit: I have not changed anything but it stopped working: CHARACTERS RECEIVED: 0
Edit2: I have found the Error
Now I only need to solve the problem of multiple characters.
Edit3: I have forgotten to set DEBUG_SERIAL false
