TCPClient.available() does not return length
Acording to the Doc, this method should return the length of the response.
But actually it only returns 0 or 1.
also in the source-code I don't see a return for the length.
sample code:
TCPClient client;
byte server[] = {127,0,0,1};
/* This function loops forever --------------------------------------------*/
	  if ( nextTime > millis() ) {
	  	return;
      Serial.println("connecting to server...");
      if (client.connect(server, 80))  {
        Serial.println("connected");
        client.println("GET /asdf/ HTTP/1.1");
        client.println("HOST: localhost.local");
        client.print("Connection: close\n");
        client.println();
        client.flush();
        Serial.println("sent request");
      } else  {
        Serial.println("connection failed");
        Serial.println("disconnecting.");
        client.stop();
        nextTime = millis() + 5*1000;
        return;
        //wait for request to be processed.
        delay(1000);
    Serial.println("waiting for response....");
    int len = client.available();
    Serial.println(len);
Output:
connected
sent request
1
Hi @Coffee,
You’re totally right! Either the documentation is wrong, or the function should be updated, I’ll add that to our bug tracker. In the meantime you could always do a read with something like:
int bufSize = 256;
byte buffer[256];
int idx = 0;
while (client.available()) {
  if (idx >= bufSize) { break; }
  buffer[idx++] = client.read();
Serial.print("Msg was ");
Serial.print(idx);
Serial.println(" bytes ");
(Note, I didn’t test this code)
Hi, thanks for clarifying.
I have a related question: in my project https://community.spark.io/t/bus-stop-light-code-review/1176
i have a delay(1000) before calling client.avalable(). is this necessary and useful, or bad?
thanks
The following commit should fix the TCPClient.available() issue:
look at the following example: https://gist.github.com/synox/b049a88bb533d7c3ec4c
it works when using a delay(2000) before reading the response. without the delay it doesn’t work. any idea how to make the coder better?
Can someone please post a complete http example?
Hmm - what happens when you don’t have the delay? It’s possible that calling client.available()before client.connect() has completed (on the CC3000 side) might cause an issue; if so, we can put in a safeguard against that.
without delay, available() returns 0.
It’s because the client.available() has no data yet, i.e. your request is taking longer than 1 second, but less than 2 seconds. When that happens your “bytes” == 0 so your for() loop gets skipped and your client.stop() is run.
On the surface, better code would be instead of the delay(2000);
// wait 5 seconds or less for the server to respond
uint32_t startTime = millis();
while(!client.available() && (millis() - startTime) < 5000);
It might be possible to put this functionality into the client.available() method… but would you really want it in there?
EDIT: I tried this in your code and it works great!
