Hi, hope I can explain the problem properly.
I run the following code :
// if an incoming client connects, there will be bytes available to read:
TCPClient client = server.available();
if (client == true)
Serial.println("Client true");
if (client.connected()) {
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println();
client.print("Hello world ");
client.println("<br />");
Serial.println("Hello world ...");
Serial.println("Client conected");
client.flush();
client.stop();
Serial.println("Client Stop");
else
Serial.println("Client not connected");
I then send any character from the TCP client. The code then keeps on looping ! Shouldn’t the flush command clear the RX buffer and then wait for another character to be received before continuing ? How do i write the code so that i can handle one character at a time ?
