I’m running a basic TCP server on my photon and everything works great while the AP is connected to the internet. When NOT connected to the internet, all works fine except that if the client disconnects, the photon doesn’t notice. I’m checking return codes on client.write() and attempted to send ping commands periodically, but it still doesn’t detect a client disconnect unless the AP is connected to the internet.
Any suggested work-arounds?
Startup code here:
#include "SparkIntervalTimer/SparkIntervalTimer.h"
// Comment this line to connect the device to the cloud.
SYSTEM_MODE(SEMI_AUTOMATIC);
#include "Particle.h"
void sendBroadcast(void);
//CANChannel can(CAN_D1_D2,1024,32);
CANChannel can(CAN_D1_D2);
int led1 = D7;
TCPServer server = TCPServer(2500);
TCPClient client;
unsigned char inbuf[100];
int connected_flag=0;
String ipStr;
int highlow=0;
int sendPingFlag=0;
int canDetectFlag=0;
#define MAX_MESSAGE_IDS 14
#define SEND_MS 500
unsigned char sendNow=0;
IntervalTimer sendTimer;
//IntervalTimer onlineDetectTimer;
IntervalTimer canDetectTimer;
//IntervalTimer pingTimer;
CANMessage signals[MAX_MESSAGE_IDS];
int main()
setup();
while(1)
loop();
return 42;
WiFi.on();
WiFi.connect();
signals[0].id=0x0D;
signals[1].id=0x1E;
signals[2].id=0x1D;
signals[3].id=0x0A;
signals[4].id=0x12;
signals[5].id=0x22;
signals[6].id=0x25;
signals[7].id=0x21;
signals[8].id=0x2f;
signals[9].id=0x64;
signals[10].id=0x65;
signals[11].id=0x23;
signals[12].id=0x20;
signals[13].id=0x6ff;
sendTimer.begin(timerCallback, SEND_MS, hmSec);
pinMode(led1, OUTPUT);
can.begin(500000); // pick the baud rate for your network
IPAddress myIP = WiFi.localIP();
IPAddress myAddress(192,168,1,189);
IPAddress netmask(255,255,255,0);
IPAddress gateway(192,168,1,1);
IPAddress dns(192,168,1,1);
//Actually set the static ip
WiFi.setStaticIP(myAddress, netmask, gateway, dns);
//Tell the photon to use the static ip
WiFi.useStaticIP();
server.begin();
if(!client.connected())
killClient();
else
digitalWrite(led1, HIGH);
void killClient()
digitalWrite(led1, LOW);
client.stop();
client=server.available();
