TCP Client Disconnect Issue
@rickkas7 i am pretty sure i’ve transmitted more data before, up to 1 MB in factt. But i was on version 0.6.3 then. this is why i suspected something was done to the firmware. I will try using a different carrier and see.
@peekay123, Yes. I am using 1024 byte packets. In fact, you can read up on some transmission analysis with different buffer sizes in my post here.
