System Deep Sleep - WakeUp event = Particle.Function()
If I put my electron into a System.sleep(SLEEP_MODE_DEEP, 86400) is it possible to wake it up by doing a POST /v1/devices/{DEVICE ID}/{FUNCTION} ?
Nope!
So there is no REMOTE way of waking it up? Either it times out or a pin goes high from a sensor or external event, correct?
In that particular mode, the entire module is in a low-power mode and only pins like WKP or RESET or the timer you set, can wake it. There is nothing awake to listen for a remote event!
https://docs.particle.io/reference/firmware/electron/#sleep-sleep-
System.sleep(SLEEP_MODE_DEEP, long seconds) can be used to put the entire device into a deep sleep mode. In this particular mode, the device shuts down the network subsystem and puts the microcontroller in a stand-by mode.
Is there a sleep mode that will save battery life that can be awakened remotely?
With a 3rd Party SIM you could use SMS to wake the Electron.
Can’t quite find the thread I’m thinking of now :blush:
If I turn off power to the GPS module (with active antenna) , will that save much in the way of battery life?
Funny I remember that thread your thinking of also but it looks to be missing or has been modified :confused:
Here is what I can find about waking up the Electron from the RI_UC pin.
Here is the thread I think we both remember. He is using the RI-UC pin in this code so the wake from SMS is probably baked into it also.
If you turn it off it will save power, figure out its rated power consumption to calculate actual power savings per hour.
It just may take a min to get a new Fix when you power it back on which is normal unless your using the coin cell battery backup which speeds up new GPS fixes on wake up.
