Just a head’s up - spark_utilities.h defines INT
, DOUBLE
BOOLEAN
in an enum - it’s quite likely these will clash with third party libraries. Libraries often define INT
so they can have a known integer size that doesn’t change with platform.
I had a clash, but was lucky! The library defined
INT
but never used it! So I just commented out the definition, and I’m good. But this might be something to put in the backlog to address at some point since it’s quite likely the clash will happen again as more libraries are ported.
