I tried string.replace(""",""); string.replace(’"’,""); none of them works.
You’re trying to remove them, right? My eyes are getting blurry trying to read that!
String withQuotes = "a \"string\"";
Serial.printlnf("withQuotes=%s", withQuotes.c_str());
String withoutQuotes = withQuotes.replace("\"", "");
Serial.printlnf("withoutQuotes=%s", withoutQuotes.c_str());
output:
withQuotes=a "string"
withoutQuotes=a string
@rickkas7
doesn’t workI am getting compile error on webIDE
String str="a \"string\""";
str.replace( "\"","");
Hi @mtun009
I reformatted your code in the post using the markup:
```cpp
<code goes here>
And it immediately showed me that you have too many closing quotes on the end of the first line.
Try without the back . it won’t compile
String withoutQuotes = withQuotes.replace(""", "");
Hi @mtun009
You know that need the backslash in the first string–check @rickkas7 nice example above for what it should look like. It does work if you write it correctly.
yes, but for the argument sake, I just want to remove the quote (") and leave the slash ().
It doesn’t remove the backslashes. The backslash tells the C++ compiler to ignore the end-of-string marker in the following character. Two backslashes in a row in a string means insert a backslash.
String withQuotes = "a \"string with backslash\\\"";
output:
withQuotes=a "string with backslash\"
withoutQuotes=a string with backslash\
Understood but actually I was trying to parse an xml data like this:
to extract value, code, name, etc.
<direction value="20" code="NNE" name="North-northeast"/>
My data string looks like below (intentionally left out <>)
direction value=“20” code=“NNE” name=“North-northeast”/
For the sake of extracting substrings I’d rather use strtok()
and not String
replacement, since it does a lot of heap messing.
But before that you might want to read up on C strings and escaping special characters in C strings.
This is what @bko and @rickkas7 tried to tell you, but you haven’t quite inhaled yet.
Hi @mtun009
I found this quick reference on C/C++ string escape sequences.
http://en.cppreference.com/w/cpp/language/escape
When the compiler comes to a backlash in string, it interprets the backslash and the next character in a special way so that they equal only one special character in the resulting string. The process is called an escape sequence and backslash is the escape character in C/C++.
