Following advise from @peekay123 I used sprintf to bring order to my output.
However, now the data is coming out in a weird format?
Code:
//Particle.publish("environment/temperature", String(bmp.readTemperature()));
//Particle.publish("environment/temperature", String(temp);
//Particle.publish("environment/pressure", String(pToHg(bmp.readPressure())));
//Particle.publish("environment/altitude", String(bmp.readAltitude(seaLevelhPa)));
sprintf(publishString,"{\"Temp\": %u, \"Press\": %u, \"Alt\": %u}",(bmp.readTemperature()),(pToHg(bmp.readPressure())),(bmp.readAltitude(seaLevelhPa)));
Spark.publish("V",publishString);
Data:
{\"Temp\": 1610612736, \"Press\": 1077454438, \"Alt\": 1610612736}
Temperature is 1610612736??
Have you tried options other than %u?
What kind of numbers are those? Integers, doubles, long, etc?
Also, some of those parentheses can be eliminated I think.
sprintf(publishString, "{\"Temp\": %u, \"Press\": %u, \"Alt\": %u}", bmp.readTemperature(), pToHg(bmp.readPressure()), bmp.readAltitude(seaLevelhPa));
if your BMP bmp.readTemperature() function actually returns a floating point number (float or double) it will be misinterpreted (as you observed).
In your case you are interpreting them as unsigned integers (the u format specifier).
You can cast the returns from your function, but unless the temperatures are in Kelvin, you may want to accommodate a signed number.
@r0b0tn1k, I think you want:
sprintf(publishString,"{\"Temp\": %f, \"Press\": %f, \"Alt\": %f}", bmp.readTemperature(), pToHg(bmp.readPressure(), bmp.readAltitude(seaLevelhPa);
If you want more/less zeroes, you could use: %.1f, %.2f, etc.
I think you misplaced a parenthesis or two.
you are correct!
sprintf(publishString,"{\"Temp\": %f, \"Press\": %f, \"Alt\": %f}", bmp.readTemperature(), pToHg(bmp.readPressure()), bmp.readAltitude(seaLevelhPa));
that should do it.
