If you mean the code to the gist; The actual code is directly below it. If not, then could you please describe what code you’re looking for?
for the reply
Hello!
I am trying to do a similar thing with the ID-12 RFID reader. I would like to return the ID number of a tag to the cloud when the reader is presented with a tag. I have tried using this example, but i do not know what changes to make? (I am indeed very new do this)
Here is the layout of the ID-12 pins.
Cheers guys thanks !
Hi, I made a new post for this question here. I think you should be able to get more visibility this way.
Is it only me or are the images missing from the first posting in this thread? I just got my Particle Electron & was going to follow this to test the PIR that came with it as one of the sensors.
Particle.publish() now
https://docs.particle.io/reference/firmware/electron/#particle-publish-
I fixed the pictures if you’re still interested.
Yes - still interested & used them to get my PIR circuit working. Thanks very much.
