I use several SPI devices while using the ethernet featherboard, and I was wondering if there are any conflicts, as I don’t know how or when the particle libraries use this bus.
Thanks ScruffR.
Acording to the post, from device OS 1.5.0 (Im using 2.0.1), you can share the primary SPI interface with he Ethernet FeatherWing (I already made the hardware, I shouldn’t, I know…)
Should I take any special precautions?
