When using the spark.publish() call, how do I insert a variable into the data type? If I’m reading the docs correct, the first condition is the name of the event you what to publish. The second is the data being published where I’d like to insert a variable fahrenheit
If it helps, I’m trying to publish the temps from a one wire temp sensor using the code from here: http://pastebin.com/iYcDkrLw#
