Spark online, but not visible on local network
It’s been a while since I’ve tried to get the Spark to work. I’m giving it another go.
Using the cli command Spark list, the Spark shows up as “online”, yet I can’t find it on the local wifi router.
How is that possible?
@ronm,
Maybe you can use http://docs.spark.io/firmware/#wifi-localip and publish or serial output to see what IP the core is using locally :smile:
