Hello, Sorry for the easy question but because i am thinking of bying a sparkfun i have to ask.
I am programming an arduino and the memory about 256 kb seem to run out and i can’t program anything else.
The spark mentioned that it has 2MB of memory does this mean that it has 8x the memory of what i currently have more or less? if so that is fantastic.
@meltoner, are you sure you are asking this in the correct community? This is not “sparkfun”. This is the forum for the Spark Core.
I have no idea where you got the 2MB from. If you look here (http://docs.spark.io/hardware/) you will find the current specs.
There is a new version of the Core in the pipeline, but AFAIK no final word about the specs.
I imagine he meant to write "Sparkcore" and instead wrote "Sparkfun." I'll admit, i've done this before if I'm distracted.
Technical Specs for the lazy:
Spark Core
ARM 32-bit Cortex™-M3 CPU Core
72Mhz operating frequency, 1.25 DMIPS/MHz (Dhrystone 2.1) 128KB of Flash memory
20KB of SRAM
12 bit ADC
USB 2.0 full-speed interface
USART, SPI and I2C interfaces
JTAG Debug mode
Arduino Uno
Microcontroller ATmega328
Operating Voltage 5V
Input Voltage (recommended) 7-12V
Input Voltage (limits) 6-20V
Digital I/O Pins 14 (of which 6 provide PWM output)
Analog Input Pins 6
DC Current per I/O Pin 40 mA
DC Current for 3.3V Pin 50 mA Flash Memory 32 KB (ATmega328) of which 0.5 KB used by bootloader
SRAM 2 KB (ATmega328)
EEPROM 1 KB (ATmega328)
Clock Speed 16 MHz
@meltoner if I am correct, you are using an arduino mega256. By moving to an arduino Due, you get double the program flash, more RAM, etc. You may want to look at the Digix board which is Due compatible.
@meltoner, of the 128K flash available on the STM32F103 of the Spark Core, 20K is used for the bootloader and about another 75K or so is used for the core firmware. The balance is left for the user application.
