I tried another thing: particle flash --usb CC3000 and I get this response:
running dfu-util -l
Found DFU device 1d50:607f
checking file /usr/local/lib/node_modules/particle-cli/binaries/cc3000-patch-programmer.bin
spawning dfu-util -d 1d50:607f -a 0 -i 0 -s 0x08005000:leave -D /usr/local/lib/node_modules/particle-cli/binaries/cc3000-patch-programmer.bin
dfu-util 0.9
Deducing device DFU version from functional descriptor length
Opening DFU capable USB device…
ID 1d50:607f
Claiming USB DFU Interface…
Setting Alternate Setting #0 …
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
dfuIDLE, continuing
Device returned transfer size 1024
Downloading to address = 0x08005000, size = 25068
Download [=========================] 100% 25068 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
Flash success!
After that, the is blinking magenta indicating it is in “OTA FIRMWARE UPDATE” (https://docs.particle.io/guide/getting-started/modes/core/#ota-firmware-update). It was in that mode for about ten minutes and nothing changed. After pressing reset, it immediately goes back to the same magenta blinking pattern and holding the mode button does not bring it into listening mode.
