SOS/S.O.S. when I change a variable name?!?
Hey has anyone else experienced SOS hard faults with minor changes on working code?
I do somewhat frequently, it is confusing and annoying. I wish there was a better way to debug things like this then SOS lights.
Here is my current one. (snippet for larger code) this compiles and works fine:
#define DATAPIN3   D2
#define CLOCKPIN3  D3
Adafruit_DotStar BOTLEFT = Adafruit_DotStar(NUMPIXELS, DATAPIN3, CLOCKPIN3, DOTSTAR_BGR);
#define DATAPIN4   D4
#define CLOCKPIN4  D5
Adafruit_DotStar BOTRIGHT = Adafruit_DotStar(NUMPIXELS, DATAPIN4, CLOCKPIN4, DOTSTAR_BGR);
this causes a SOS hardfault (all I did was swap the variable names BOTLEFT and BOTRIGHT
#define DATAPIN3   D2
Adafruit_DotStar BOTRIGHT = Adafruit_DotStar(NUMPIXELS, DATAPIN3, CLOCKPIN3, DOTSTAR_BGR);
#define DATAPIN4   D4
Adafruit_DotStar BOTLEFT = Adafruit_DotStar(NUMPIXELS, DATAPIN4, CLOCKPIN4, DOTSTAR_BGR);
I “undo” and re-flash and everything is back to normal.
WHY DOES THIS MATTER? Please help me understand…
I don’t see a reason why the naming should make a difference, but try to do this instead
Adafruit_DotStar BOTRIGHT(NUMPIXELS, DATAPIN3, CLOCKPIN3, DOTSTAR_BGR);
Adafruit_DotStar BOTLEFT(NUMPIXELS, DATAPIN4, CLOCKPIN4, DOTSTAR_BGR);
The other way you’ll first create a BOTRIGHT and a temporary object and then assign the temp object to the original BOTRIGHT and the same for BOTLEFT.
sorry to have disappeared, thanks for the feedback. That is clear thinking, as far as declaration goes I was mindlessly using the example code from the library.
-but it didn’t help…
It turns out that the panic is happening when I call this one function… it got a <0 value for something that didn’t like it apparently. How the variable name or pin assignment related, I don’t know. I have fixed this bug and now things seem fine as far as renaming variables, maybe someday I’ll dig around to find out why.
