[Solved] You can expose a method on a C++ object to the Cloud
Hi Everyone,
The example found [here][1] suggests you can expose a class method to the cloud e.g.
class CoffeeMaker {
  public:
    CoffeeMaker() {
      Particle.function("brew", &CoffeeMaker::brew, this);
    int brew(String command) {
      // do stuff
      return 1;
I tried this and received some compiler errors which suggest Particle.function does not even have 3 arguments:
 In instantiation of 'static bool CloudClass::function(const T&, Types ...) [with T = char [5]; Types = {void (OneWireInterface::*)(), OneWireInterface*}]':
OneWireInterface.cpp:12:60:   required from here
../wiring/inc/spark_wiring_cloud.h:191:39: error: no matching function for call to 'CloudClass::_function(const char [5], void (OneWireInterface::*&)(), OneWireInterface*&)'
         return _function(name, args...);
../wiring/inc/spark_wiring_cloud.h:191:39: note: candidates are:
../wiring/inc/spark_wiring_cloud.h:194:17: note: static bool CloudClass::_function(const char*, int (*)(String))
Does anyone have a solution?
  [1]: https://docs.particle.io/reference/firmware/photon/#particle-function
Sorry!
I realized the signature must be
int func(String s) {};
:grin:
