Hi all,
I have a problem in order to using a communication between 2 Particle Photon via XBEE.
This is my configuration:
Photon1 ----> XBEE_A -------------------------------------> XBEE_B ----> Photon2
XBEE_A is in API mode
XBEE_B is in Transparent Mode.
If I connect XBEE_A via XCTU and I send data to Photon2 this work fine.
If I send data from Photon1 via SPI ports Photon2 doesn’ receive nothing.
I have connected pin of Photon1 like this:
Photon1 XBEE_A
A2(SS) pin 15 (SPI_nSSel)
A3(SCK) pin 14 (SPI_Clk)
A4(MISO) pin 17 (SPI_MISO)
A5(MOSI) pin 16 (SPI_MOSI)
and this is a simple test code in Photon1:
SYSTEM_MODE(MANUAL);
byte sendData;
pinMode(SS,OUTPUT);
digitalWrite(SS,HIGH);
SPI.begin(SPI_MODE_MASTER,SS);
SPI.setClockSpeed(1, MHZ);
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE0);
WiFi.off();
digitalWrite(SS,LOW);
sendData = 0xFF;
SPI.transfer(sendData);
digitalWrite(SS, HIGH);
Serial.print("\nSend to Photon2=");
Serial.print(sendData);
delay(800);
Who can help me?
Best Regards,
Michele.
