[SOLVED] Why does my code not compile?
SOLUTION: Don’t use “index” as a variable name (among other things)
here is my incomplete code. Cam you find bug(s) in it?
// constants won't change. They're used here to
// set pin numbers:
const int RedLedPin =  A5;
const int GreenLedPin = D0;
const int BlueLedPin = A4;
const int buttonPin1 = D6;
const int buttonPin2 = D4;
const int buttonPin3 = D2;
// variables will change:
int buttonState1 = 0;
int buttonState2 = 0;
int buttonState3 = 0;
int index = 0;
int returnB = 0;
int ModeIndex = 0;
char *ModeList[] = {'Basic', 'Blink', 'Fade', 'photoColor', 'photoBlink'};
  // initialize the LED pins as an output:
  pinMode(RedLedPin, OUTPUT);
  pinMode(GreenLedPin, OUTPUT);
  pinMode(BlueLedPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin1, INPUT);
  pinMode(buttonPin2, INPUT);
  pinMode(buttonPin3, INPUT);
  Modes(ModeList[ModeIndex])
void Modes(char Mode) {
  // Basic
  if(Mode == 'Basic'){
    char MIXORLIGHT = 'MIX';
    returnB = clickCheck(300);
    while(returnB != 2){ // not sure
      colorPallete(MIXORLIGHT, index);
      if(returnB == 1){
        index = index + 1;
      else if(returnB == 3){
        if(index > 0){
          index = index - 1;
      else if(returnB == 7){
        if(MIXORLIGHT == 'MIX'){
          MIXORLIGHT = 'MIXLIGHT';
        else if(MIXORLIGHT == 'MIXLIGHT'){
          MIXORLIGHT = 'MIX';
  // Blink
  else if(Mode == 'Blink'){
  // Fade
  else if(Mode == 'Fade'){
  // PhotoColor
  else if(Mode == "photoColor"){
  // PhotoBlick
  else if(Mode == "photoBlink"){
void colorPallete(char color, int colorIndex) {
  // MIX of colors for Basic, Blink, Fade
  if(color == 'MIX'){
    if(colorIndex == 0){
      rgb(22, 160, 133);
    else if(colorIndex == 1){
      rgb(39, 174, 96);
    else if(colorIndex == 2){
      rgb(41, 128, 185);
    else if(colorIndex == 3){
      rgb(142, 68, 173);
    else if(colorIndex == 4){
      rgb(44, 62, 80);
    else if(colorIndex == 5){
      rgb(243, 156, 18);
    else if(colorIndex == 6){
      rgb(211, 84, 0);
    else if(colorIndex == 7){
      rgb(192, 57, 43);
    else if(colorIndex == 8){
      rgb(189, 195, 199);
    else if(colorIndex = 9){
      rgb(127, 140, 141);
  // Light MIX
  else if(color == 'MIXLIGHT'){
      rgb(26, 188, 156);
      rgb(46, 204, 113);
      rgb(52, 152, 219);
      rgb(155, 89, 182);
      rgb(52, 73, 94);
      rgb(241, 196, 15);
      rgb(230, 126, 34);
      rgb(231, 76, 60);
      rgb(236, 240, 241);
    else if(colorIndex == 9){
      rgb(149, 165, 166);
  // RED color Shades
  else if(color == 'Red'){
      rgb(252, 180, 184);
      rgb(251, 143, 148);
      rgb(249, 106, 113);
      rgb(248, 69, 77);
      rgb(248, 69, 77);
      rgb(248, 51, 60);
      rgb(226, 47, 55);
      rgb(181, 38, 44);
      rgb(136, 28, 33);
void rgb(int red, int green, int blue) {
  red = 255 - red;
  green = 255 - green;
  blue = 255 - blue;
  analogWrite(RedLedPin, red);
  analogWrite(GreenLedPin, green);
  analogWrite(BlueLedPin, blue);
void clickCheck(int delayTime) {
  buttonState1 = digitalRead(buttonPin1);
  delay(delayTime);
  buttonState2 = digitalRead(buttonPin2);
  delay(delayTime);
  buttonState3 = digitalRead(buttonPin3);
  if(buttonState1 == LOW && buttonState2 == LOW && buttonState3 == LOW){
    return 0;
  else if(buttonState1 == HIGH && buttonState2 == LOW && buttonState3 == LOW){
    return 1;
  else if(buttonState1 == LOW && buttonState2 == HIGH && buttonState3 == LOW){
    return 2;
  else if(buttonState1 == LOW && buttonState2 == LOW && buttonState3 == HIGH){
    return 3;
  else if(buttonState1 == HIGH && buttonState2 == HIGH && buttonState3 == LOW){
    return 4;
  else if(buttonState1 == LOW && buttonState2 == HIGH && buttonState3 == HIGH){
    return 5;
  else if(buttonState1 == HIGH && buttonState2 == LOW && buttonState3 == HIGH){
    return 6;
  else if(buttonState1 == HIGH && buttonState2 == HIGH && buttonState3 == HIGH){
    return 7;
We probably could, but without error messages it’s looking for a needle in a hay stack - provide more info.
in C++ single quotes are used for char data type:
and then you go on to make a char comparison as if they were String data types:
if(Mode == 'Basic')
try the enum resource
I’m trying to achieve A.
To do so, I’ve tried B.
It’s doing C.
The error is X.
That’s something we might be able to help with, and if nothing else, it shows you’ve at least made an effort to do so yourself.
Currently we’ve got:“Here’s B, fix it?”.
thanks, I didn’t knew that single and double quotes were different (I’m coming from python).
Sorry, I will provide you with more info.
ok, I get this error message:
rainbow.cpp:15:5: error: 'int index' redeclared as different kind of symbol
how can I fix this?
ok, I get it now. I shouldn’t use ‘index’ as a variable name.
