Hi there , I am instersted in using node.js to make a http post to call particle.function by my photon.But I know nothing about JS .What I usually did is using the postman to POST.Have anybody every post with node.js and can provide some simple examples that will be grateful.
Considering you’ve solved your own issue, would you mind sharing this with the community, so other may benefit from it as well?
Hi,I just follow the what you ever send [here][1]
