@ScruffR I talked to you before on the Nextion forums but you said this would be a better spot to get ahold of you. Thanks again for the library it has been working great so far. I’m getting caught on one spot though. For the project I am working on I would like a wheel with 31 segments to spin (each segment is filled in in each of the different pictures). I’m running into the issue of converting a bool to a void. I know this is due to the library. I was wondering if you or anyone else has a way to get the code to work. Here are some snips of my code.
In the library this is the PopCallback function. I do have the picture object initialized at the top and do attach the pop. However I don’t want the wheel to spin after a touch event. I would like it to spin once the screen turns on (so I want to call this function in the setup function). Does anyone know how I can call this function to run how I would like it?
Any help is appreciated!
