[SOLVED]Trouble with the pow() function?
Hi at the community,
I have a, hopefully, pretty simple problem, which I simply can’t figure out. I’m trying to compile the following code, but I get this error message: “‘pow’ was not declared in this scope”
I have been looking at the reference documentation and it seems correct to me.
    const int irsensorpin = A0;
  // put your setup code here, to run once:
void loop(){
  // Reads the InfraRed sensor analog values and convert into distance.
  double sensorValue = analogRead(irsensorpin);
  double IRdistance = 6560.7 * pow(sensorValue, (-0.517));
  Serial.println(IRdistance);
  // A delay is added for a stable and precise input
  delay(500);
I have also tried to change the base to a float like this, but I get the same error.
  float sensorValue = analogRead(irsensorpin);
Hope you guys can help me :grinning:
Regards Mads
Just include this at the top of your source file:
#include <math.h>
Many things are automatically included for you, but math.h is not.
Thanks a lot :smile:
Thanks for the quick fix and answer Rick!
