[SOLVED] Sscanf not working like it should
I can’t get sscanf to parse a string correctly.
Check out the code below, and the output:
Code
#include "Particle.h"
SYSTEM_MODE(SEMI_AUTOMATIC);
SYSTEM_THREAD(ENABLED);
void setup(){
   Serial.begin(115200);
   while(!Serial.available()){};
   uint16_t r1, r2, r3;
   unsigned int r4;
   uint16_t r5, r6, r7;
   float r8;
   const char* toParse = "1,1,0,1493711570,666,777,1234,  1.23\r\n";
   int result = sscanf(toParse,
         " %u,"" %u,"" %u,"" %lu,"" %u,"" %u,"" %u,"" %f\r\n",
            &r1, &r2,  &r3,   &r4,  &r5,  &r6,  &r7,   &r8
   Serial.printf("result == %d ... parsed values are: \r\n", result);
   Serial.printf(      "  Parsed: %u,""%u,""%u,""%lu,""%u,""%u,""%u,""%f\r\n",
                           r1,   r2,   r3,    r4,   r5,   r6,   r7,    r8);
   Serial.printf("Original: %s\r\n\r\n", toParse);
void loop(){
Output
result == 7 ... parsed values are:
  Parsed: 1,1,0,1493696512,666,777,1234,0.000000
Original: 1,1,0,1493711570,666,777,1234,  1.23
_
_
Yet when I run the exact same code in C++ shell I get the correct parsing (see working program here) :
result == 8 … parsed values are:
Parsed: 1,1,0,1493711570,666,777,1234,1.230000
